Old 04-10-2009, 04:50 PM   #1
Geronimoo
Geronimoo is on a distinguished road
will these rims fit?
After some searching of the forum, there was too many conflicting answers so I was left unsure. So I would like to know for certain if these rims will fit an unmodified Alero without sticking out or inappropriately touching something.
Rim Width: 8.5J
Rim Diameter: 18 inches
Offset: 42
Studs: 5x112
Geronimoo is offline   Reply With Quote
Old 04-10-2009, 05:28 PM   #2
Vic28
Vic28's Avatar
Vic28 is an unknown quantity at this point
Send a message via MSN to Vic28
No. Wrong lug pattern; to wide for that offset.
Vic28 is offline   Reply With Quote
Old 04-10-2009, 05:28 PM   #3
worknprog.99
worknprog.99's Avatar
im pretty sure they will not.
Old 04-10-2009, 05:58 PM   #4
nope you need 5x114.3 or 5x115 the offsets fine as long as its +38 to +42
Old 04-10-2009, 06:51 PM   #5
Geronimoo
Thanks for the replies!
I might get a set that is like this instead:
Rim Width: 8.5J
Offset: 35
Studs: 5x114
Im worried that the offset + the width of 8.5 will cause problems.
Old 04-10-2009, 08:34 PM   #6
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
go on 1010tires.com ,theres a offset calculator to see if it fits right!
leoalero is offline   Reply With Quote
Old 04-10-2009, 08:35 PM   #7
yes they will probably rub with that offset and width.....
Old 04-10-2009, 10:42 PM   #8
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
true. with the wider wheels, you want to go with the higher end of the offset range...just to be safe.
Old 04-10-2009, 11:19 PM   #9
just for reference, my 17x8 wheels fit perfect, and they have a +32 offset.....
Old 04-11-2009, 06:08 PM   #10
Geronimoo
Ah well! I bought some other rims after all. They should fit snugly!
18" 114, 42 offset
Thanks for the advice!
