leaking thermostat??
so i put a thermostat in my ld9, i was doin final check before i crank her over for the first time, after i added the water i heard a trickling noise, and my first thought was the water pump. but when i got under i saw it was coming from the tstat. so i dropped the water pipe and checked everything seemed to be ok, new gasket and thermostat. so i put a biitle bit of rtv around the gasket put it back in torqued it down waited awhile and added more water but the same thing. one side keeps leaking? any ideas? its in flush and its not backwards.
