Old 06-20-2008, 03:46 PM   #1
leviathan1888
leviathan1888's Avatar
leviathan1888 is on a distinguished road
Dummy lights/cruise question
I recently had my 2.4L switched out and ever since then, I have been having the TRAC OFF and Anti-Lock lights coming on through-out the days. I have read up that it could be the sensor in the hub of a wheel.
Like I said its been since this new engine was put in, and recently found that the cruise is not available for the new engine. Can the cruise not being there affect any of these lights?
1999 Alero GX
Nothing Special
leviathan1888 is offline   Reply With Quote
Old 06-20-2008, 08:25 PM   #2
super white alero1
Trying to get it together
super white alero1's Avatar
New engine? Sorry unless its crate its not new. Maybe reman. Anyways, is it TRAC only or TRAC red brake and ABS?
Old 06-20-2008, 08:36 PM   #3
leviathan1888
TRAC OFF and ANTI-LOCK(ABS) are the two showing...
Man I hate being corrected...okay yes not new engine hehe
1999 Alero GX
Nothing Special
Old 08-04-2008, 09:16 PM   #4
blackbeast
blackbeast's Avatar
blackbeast is on a distinguished road
check to see if the abs wire got rapped around your ball joint or somewhere else and stretching the wire or grounding out on the axel
blackbeast is offline   Reply With Quote
Old 08-04-2008, 10:44 PM   #5
if your old engine had cruise your new one does, it has nothing to do special with different engines its a separate part. they lied there.
You sure those r the only lights? kinda sounds like a ABS sensor/wheel hub, but u said no SVS light?
Old 08-04-2008, 10:54 PM   #6
I've heard this before... Take apart the cluster and put black tape over those 2 lights and they go away.
