08-15-2010, 03:43 PM
properly bleed the clutch
hey guys, i just need to know the proper procedure for bleeding my clutch
the container is full. but i still need to bleed it
is it, push clutch to flour, open valve, close valve, bring clutch up, and repeat?
or can i put the bleeder valve in a cup of brake fluid, and just pump like a mad man
08-15-2010, 07:27 PM
well if you put it to the flour nothing will happen
stock 2.4 -building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
08-15-2010, 07:55 PM
i got that far already
08-15-2010, 10:22 PM
well, i dont know anything about bleeding the clutch but i vote for pumping like a mad man
08-15-2010, 10:36 PM
I expect it would be similar to brakes; open valve, push clutch to floor, close valve, bring clutch up, and repeat.
08-15-2010, 10:37 PM
lol, i'm doing that. everyime i go to drive the car, i have to pump it like a mad man, get it into gear. and if i go on a long highway drive, pump like a mad man again lol.
08-15-2010, 10:39 PM
08-16-2010, 12:50 AM
sounds like you may have a master cylinder problem.
08-16-2010, 09:33 AM
possibly. but it was working properly, but then i tried to bleed it, and effed up
02-12-2011, 11:19 AM
I had issues with my master cyl, started with extreme cold times only, clutch would barely make it back up after I pressed it and it finally led to failure, they decided at the shop to try and replace the slave and clutch assembly first :-( ....... Gave the car back to me and it worked of course after leaving the warm shop but the next morning when it cooled off -35C same prob happened. They flushed the fluid and changed out the master cylinder this time and then everything worked excellent. They finally traced it to master cylinder failure.
