Old 09-11-2006, 06:54 PM   #1
sushko
sushko is on a distinguished road
Send a message via AIM to sushko
ebay turbo
hi guys i found a turbo off ebay and it has every thing that i can think i need of 400 should i get it or what else do i need
sushko is offline   Reply With Quote
Old 09-11-2006, 07:06 PM   #2
Post a link, we need pics.
When you say "everything" for $400 does it have:
Turbo
Headers
PCM
gaskets
mounting brackets
higher psi injectors
higher psi fuel rails
etc etc etc
Old 09-11-2006, 07:40 PM   #3
alerocar01
alerocar01's Avatar
Turbo
Headers
PCM
gaskets
mounting brackets
etc etc etc
ditto
Old 09-11-2006, 07:47 PM   #4
sushko
cgi.ebay.com/ebaymotors/95-02-98-99-CHEVY-CAVALIER-2-2L-TURBO-INTERCOOLER-KIT_W0QQitemZ250026522925QQihZ015QQcategoryZ33742Q QrdZ1QQcmdZViewItem
with out the pipe
what else do i need
Old 09-11-2006, 11:27 PM   #5
Spilner521
Boost Guru
Spilner521's Avatar
They're all knock off parts. There's nothing engine specific about any of that "kit" and you get a bunch of pipes that you'd have to cut and fab yourself. Most likely if you do get all those parts, you'll have to add many other parts to it to get it to work as an actual turbo kit. Even then, those knockoffs will most likely fail and cause damage to your engine, which will end up costing you more to fix than the turbo kit itself.
If you want to go turbo, do it right the first time using quality parts.
Old 09-12-2006, 12:35 AM   #6
mrmike
mrmike's Avatar
yeah dude turbo kits don't cost $400.
Old 09-12-2006, 12:52 AM   #7
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
i agree with both spilner and mike, i wouldn't trust that at all... maybe for a cai for the v6, but i wouldn't take any risks of getting a turbo for that cheap..... it doesn't sound right to me....
i like how they have "shiney chrom piping" lol wtf
battistoni21 is offline   Reply With Quote
Old 09-12-2006, 12:54 AM   #8
You WILL blow the motor with that.
It will run too lean and just blow it. Without the PCM upgraded, the fuel mixture will not be correct and not enough fuel will get in the motor, causing the motor to blow. Most likey it would happen at WOT too.
