12-27-2008, 01:20 AM
Anyone??
so today my radio and cd player was working fine and then i went to use it again a half hour later and everything kights up and works except for the sound.. anyone know what could have caused this??
12-28-2008, 03:26 PM
all the veiws to this thread and nobody has even a guess?
12-28-2008, 03:31 PM
blow a fuse?
im not an audio guru, idk dude...
12-28-2008, 04:05 PM
I'm no audio guru either, but here are a few of my uneducated guesses.
-Maybe the speakers are completely burned out
-Maybe the speaker wires got messed up somewhere
-If your car leaks, like mine, maybe the water caused a short with the wiring (happened to me once).
-Or your stereos speaker outs could have burned out. This would cause the stereo to light up, but not produce sound as well.
12-28-2008, 07:47 PM
ninja's or gremlins, thats my geuss. Honestly though, burned out fuse, bad connecting some where.
1999, RED Alero GX
12-28-2008, 08:13 PM
Let's Play Army!
ninja gremlins.
seriously, this happened to me a few years ago. I went driving through a huge puddle. the doors filled up (well, really wet on the inside too) and speakers were soaked. Sound didn't work at all. I let them dry for a couple days and they worked fine.
Nick and Valley's ideas sound plausible too. if you have a volt meter, check the speakers out.
Originally Posted by black
12-28-2008, 10:31 PM
ok so heres the problem now...the sound works but no lights on the radio screen or the gauge clusters or the "park , reverse neutral etc..." on the actual shifter colum thing itself??? so... any ideas now after some more info?? lol
12-28-2008, 11:03 PM
Originally Posted by AlbinoMonkeyRat
ninja gremlins.
my radio stops lighting up as well, but only if it gets hot. dose yours over heat?
1999, RED Alero GX
12-29-2008, 08:02 AM
check fuses. thats always is step 1.
replace the one on the passanger panel, top left. see how that works.
12-29-2008, 02:02 PM
my stereo has done this too me twice. I hit the dash and away it goes.
12-29-2008, 03:16 PM
which means its a loose connection somewhere...
12-29-2008, 04:21 PM
All external connections are soldered and heat shrinked.
..what do you suggest?
12-29-2008, 04:41 PM
Do you have amps hooked up to your speakers, front and rear? Sometimes if the amps get too hot, no sound.
12-29-2008, 11:38 PM
nope stock....its weird sometimes the radio works as normal(lights and sound) other times just sound or just lights. and the gauge lights and shift lights have not yet turned back on....its wuite frustrating on top of the fact i have an intake manifold gasket leak, spewing coolent into the oil,,, luckily my mechanic at my work (car dealership) is hoonking me up 280 for labor and parts
12-30-2008, 08:21 AM
I hate the stock radios for these cars with a passion. They are doomed to fail...each and everyone, and if it hasn't yet it will. You may need to find a wiring diagram of the lighting circuit and start checking all fuses and relays.....etc. Sounds like failing components of some type....could also be some intermittent relays, of course I'm just speculating.
12-30-2008, 08:09 PM
thank you lol im clueless
12-31-2008, 07:49 AM
Go to the thread below and look up the wiring diagram for your car...I look at my diagram and if they are similar then I would check the Auto park lamp relay in the engine bay fuse block, then I would check on the passenger side fuse block and look at the Inst LPS fuse. You may also want to check the dimmer switch and the dimmer module because in my car (don't know about yours) all the interior lights are feed from the dimmer module, which is in turn feed by the dimmer switch. Could be a bad module or switch. Good luck!
http://www.aleromod.com/forums/showthread.php?t=19347
12-31-2008, 10:51 PM
^^ thank you ^^
i hope i can figure it out..
12-31-2008, 11:24 PM
If you need a stock radio I have one from a 2000 Alero GX
let me know, if your radio is the problem, and you choose not to go aftermarket. But personally, I'd go aftermarket.
01-01-2009, 02:18 PM
how much would you want it for??
i had an aftermarket and sold it a while ago...so stock replacement is fine.. if that turns to be the problem lol
