Old 02-12-2014, 11:10 AM   #1
negolien
Multi amp help
Hey All,
Well the Alero is in the shop getting brakes so it gives me a week or two to take another look at the system.
I am running 1 500/1000 for subs and one 45/150 for 4x6's...I will be ditching the Monsoon amp that runs the 6x9's in the not to distant future for a 150/300 amp. This brings up the hum maybe I should start looking at how I' am going to wire all 3 amps. I might as well get the block and stuff and have it wired in now with the 4x6 amp so it will be easy to add the last amp. Any thoughts?
Old 02-12-2014, 12:56 PM   #2
S8track16
S8track16's Avatar
I would recommend the KnuKonceptz KNF-60: http://www.knukonceptz.com/productDe...rodid=KNF-60x3. It's a 3-way distribution block, you get the fuses with it (make sure you know which sizes). I currently have one for 2 amps but that's because I use it for power and ground, with three amps you use it just for the power distribution. Then you can ground somewhere else.
Old 02-12-2014, 01:59 PM   #3
negolien
Thanks I need an amp wiring kit for the new 4x6 amp maybe I can find a monster with a distribution block. I'll look around the crutch and frys.
