01-09-2010, 10:50 PM
so i tried the rims again and what....
Ok so I was going to get these rims but as u guys know... left side doesn’t fit...
So I was going to get spacers... well I don’t know what size to get...
The rims have a 20 offset and so I was thinking a 15mm offset but I am unsure...
The alero comes with 35 45??
So add 15mm to that???
I tried on a 7.9 mm spacer today helped allot just need a little more and didn’t look bad like if it was sticking out so...
whatcha think??
any help with my car i will look in on and love!
01-10-2010, 12:31 AM
Help.... Noone has ever had this prob... Or can u guys just not read my sloppy iPhone textin....
01-10-2010, 12:52 AM
the last 2 sets of rims i have had are +38 and +40 offset and i havent ran into any problems with them
01-10-2010, 12:59 AM
Why not get the right rims for the car?? Are they free, pretty cheap or what??
01-10-2010, 02:26 PM
Sounds like you'll need a 20 spacer to get it right, if you insist. That will probably require longer bolts in order for the nuts to have enough thread to be safe. Not the best option, like previous asked, are these real cheep or special or what?
01-10-2010, 02:57 PM
Yea I don't have much money and my friend has a g35 and and he took these rims off along time ago... And I said I would buy then from him...
He's handingtjem away for 300 with nice rims and 4 brannew z tires
And I need tires now!!! LOL I am bald...
My mom works at a caddilac dealership and I can get nice tires for 77 each...
And I can get this same price y not... Right?
01-10-2010, 03:59 PM
Yo just try the wheel in the back and see what happens... Cause most G35 have different size tires front and back. I know these are aftermarket wheels. You already said that the wheels are the same width on another thread ( 18x8 with +20 offset) correct?? Now whats the size of the tires?
01-10-2010, 06:45 PM
All the rims and tires are the same...
The front left rubs but just barely the right front, the back left and the back right.. All are fine
just this one and bcause it is just Barely rubbing I plan to
take off the weel well plastic and make a small cut at th fender pinch and the world will be fine again... I hope that works
01-10-2010, 07:23 PM
Yes correct.
size is 225/40Z?/18
01-10-2010, 07:32 PM
OK, the rim size you have is 18x8 and the biggest tire you want is 235-40
18... the offset should be around +35 to +42, depending on the rim with..
225/40/18 are fine as well...
Good luck.
BUILDING A V8 ALERO 2DR
01-10-2010, 07:38 PM
Good luck.
thanx it all should work outthe offset is 20 and the spasers only made it worse...
i tried a 7.9 mm
then a 15 mm
just made it worse so went back to flat out and i am gonna hammer it
01-11-2010, 12:30 AM
hammer what?
01-11-2010, 12:44 AM
Originally Posted by Rubiks43
just this one and bcause it is just Barely rubbing I plan to take off the weel well plastic and make a small cut at th fender pinch and the world will be fine again... I hope that works
that, i think...
01-11-2010, 02:26 AM
Seems like your spending a lot of time and money for the wrong thing.
Doing it right would save you a lot of money
01-11-2010, 10:54 AM
The only reason I can see for one side to fit and the other have this issue is if there has been some damage done to cause the a arms to be out of alignment. Like a hard curbind or hitting a rock with one tire which can push everything back on one side. I'd have an alignment shop or frame place check things out. Maybe measuring front to rear on each side will show where the problem is...
BTW - those are 114x5, not 115x5 and the centerbore is wrong. You should be using hub rings at least
01-11-2010, 11:50 AM
Yea they where hub rings with extenders on them they made it worse... So I will check the alinment and hammer it just incase
01-11-2010, 11:51 AM
Originally Posted by Gr1m
hammer what?
It's hitting a small fender pinch... So I'll just bash it in
01-11-2010, 11:52 AM
I have not spent any extrra money... I haven't even got the rims yet so no money spent just trying to make it work...
