09-14-2011, 12:15 AM
3500 swap in the works....
The time has come....3500 will get swapped in....port and polished upper and lower intake mani with 65mm TB and the S&S headers i have on the 3400..gonna swap them right over Going through WOT-tech
09-14-2011, 01:28 AM
Good luck with the swap. Keep us posted
09-14-2011, 09:00 AM
Full 3500 swap, or just top end?
09-14-2011, 10:01 AM
Good luck man...
09-14-2011, 11:58 AM
needs moar 5speed
09-14-2011, 12:23 PM
When you're done, meet me at the track.... lets see how you fair against a 3400, wink, wink...
09-14-2011, 12:38 PM
Full swap
LOL....you prob have yours all built up right? judging by the posts you make im assuming you do....if not, LETS GO!
09-14-2011, 02:25 PM
Yea its built. I was thinking you were building a 3500 and dropping it in. I am dying to see how I would do against a built 3500
09-14-2011, 05:16 PM
Not really gonna build up the engine too much. just getting the upper and lower intake mani's port&polished, bigger tb, headers, exhaust. 200+ hp is enough for me. Canada is a little far a drive too...lol
09-14-2011, 08:09 PM
good luck I wanna see this !!
09-19-2011, 10:14 AM
K....im searching for possible sites to buy an engine from but i dont wanna just buy from ANY site....found this one.
http://www.psengines.com
then i did a little search and found a 3800 supercharged on there....no 3500 but im sure i could request one. There is a 97-05 buick built 3800 supercharged....its very tempting....but first i should talk to guild about how much goes into that swap.....both swaps i would need to do A LOT of work right? like swapping computers and stuff....$2,179 for the 3800
09-19-2011, 12:07 PM
for the 3500 its pretty much a bolt in engine, all you need is the 65 mm TB and the adaptor, you also need the crank position sensor relocation kit avaiable from WOT
09-19-2011, 12:10 PM
Nice....did you do the swap?
09-19-2011, 01:02 PM
15.65 @ 87.3 MPH
The 3500 uses a different MAP sensor...i think you'll need a pig tail to get it work.... PM 3500Alero he actually had this swap
09-19-2011, 07:33 PM
You can get all the stuff you need for the swap at MilzyMotorSports.com.
2002 Grand Am GT Turbocharged
Garrett GT35 / Turbo Headers / 2.5" high flow DP / 60lb Injectors / Custom SLP Exhaust / Ported 3500 Heads / Ported 3500 UIM/LIM / 65mm TB / Turbonetics Evolution WG / Greddy Type-RS BOV / Casper Adjustable FPR / Casper High Speed Fan Switch / Speedbuilt F/R STB's / Next Level F/R Sway bars / Eibach Springs / Dual Gauge Pod with Aeroforce Gauges / Big Four Upgrade / HP Tuners and more!
"Living is doing everything you want to do and dying is everything else"
09-19-2011, 09:09 PM
not yet im not finished gathering all the parts i need, when i do mine its getting a 5 speed as well, you kno so all that power wont get soaked up by the auto tranny lol
09-19-2011, 11:21 PM
my buddy has a ga 3.5 swapped with 5speed, motor was a direct swap tranny was a pain tho
09-20-2011, 12:04 AM
yea not looking forward to the tranny thing
09-20-2011, 05:02 PM
Okay ,sorry for being a total moron when it comes to the aleros v6 power plants since i my self got a 2.4l twin cam, don’t really know much more like nothing about those two engines. What exactly would be the benefit of doing this engine swap. Pleas enlighten me with the knowledge I seem to lack.
yeah right!
09-20-2011, 10:36 PM
Better compression, better flow, better crank, and more HP. The G6 motor is essentially the same motor but it was a little redesigned internally with the crank, cylinder heads, and intakes. Plus stock it is a 200HP motor. The cool thing is everything bolts up the same minus a few sensors that have to be changed over.
