05-19-2014, 10:32 AM
#221
How you making out Sleepy? Any scans to have a look at from where you were the other day??
05-19-2014, 01:05 PM
#222
Sorry paul. Been a little busy. I plan on getting one today so ill report back later letting you know I sent the email!
Originally Posted by Oldsnut
Originally Posted by tipnitty
05-20-2014, 12:18 AM
#223
email sent!
05-25-2014, 11:46 PM
#224
Paul email sent few days ago when u asked for current tune.
05-26-2014, 06:03 PM
#225
Found it Sleepy.... having a look now bud
05-26-2014, 06:15 PM
#226
Cool thanks!
05-26-2014, 06:17 PM
#227
Open your current tune, you are a little lean WOT but really close. Open your VE table under the "Airflow Tab". Highlight the bottom rt corner of the table from 4800 rpm to 6400 rpm and from 100kpa out to the 140kpa. You should have a square highlighted that is 5X5 squares. Then multiply that highlighted section by 0.985, this should land you dead nuts at 13.0:1 when WOT. Right now you are hitting 13.2 to 13.3. Not bad, but I found my best et and quarter was aiming for 13:1 plus 13:1 is very safe for these engines bud
05-26-2014, 06:21 PM
#228
I'd like to add, your choice in injectors was perfect! I like it, 75% at 6000RPM... Id like to see a 6400RPM shift if your willing to go that high. As long as we stay 80% or less on the Duty Cycle your good to go man!!
05-26-2014, 07:19 PM
#229
My choice in injectors?? They are stock! Hahaha
05-26-2014, 07:28 PM
#230
But thanks im not near my computer atm. Ill have to make changes later. Sounds a little confusing I might be back with questions later
05-26-2014, 11:07 PM
#231
Pretty surprised your injectors are stock! Your hitting what I was hitting % wise with 36lb ones man! If they can feed it to 6400 and stay at that 80% mark then no need to touch them. That's a good thing man, money you don't need to spend...lol
05-27-2014, 01:20 AM
#232
Havent touched the tune yet. I may just mess with it tomorrow at work and do a scan on the way home if I can figure out the new adjustment you want. Will I need maf unplugged again?
Also. The car is still stock motor. It has 204k miles on it (including injectors) is 6400 rpm a safe thing to do? I was a little worried going to 6000 when you first told me to just because I have never had it that high before. I always steered away from the red on the tach hahaha
05-27-2014, 07:07 AM
#233
okay paul, at work and just made the adjustment to the tune, ill get a scan on my way home from work!
05-27-2014, 01:47 PM
#234
okay paul, did a scan on my way home. few things for you..... after I type this out, I will shoot it over to ya via email.
anyway,
1. I did one high rpm pull for you, ended up around 6327 rpm.... after I went over 6150-6250 ish... somewhere in that range. the car kind of kicked... like idk how to explain this umm... it kinda of studdered. like you hear it vrrrooooooommmmmm then kinda studdered then would be a steady increase again then studder (studdered like twice once over that rpm range) but before that was fine, and after the pull was fine at 6k or under. I assume the injectors didn't like it?? lol
2. ive noticed a big decrease in my delivered trans tq. does the maf being unplugged play a part in this? the hot weather? its a humid 85 degrees here. previous scans (maf plugged in) I saw as high as 242 ft lbs IIRC. recently I have been seeing a max of 232 rarely but more in the 210-225 range... just curious on that.
also I had the maf unplugged for this scan. shooting it over..
05-27-2014, 04:20 PM
#235
Now its making sense man, being stock do not exceed 6200 RPM MAX... Going to look at your scan, and if you were overfueling before, ie: Too Rich, that will give false high Tq numbers. Since your fuel is more in line to where it should be now, your going to see lower reported tq numbers, and in actuality, more of what you would expect to see on a dyno
05-27-2014, 04:29 PM
#236
don't see your e-mail here either... wanna re-send?
05-27-2014, 05:46 PM
#237
Okay paul. And yeah I will re send here in a few!
05-28-2014, 09:33 AM
#238
sorry for the delay paul, just resent the email
05-28-2014, 10:05 PM
#239
Got your e-mail and replied...
05-29-2014, 01:26 AM
#240
Thanks paul. Will scan tomorrow or fri night.
