Old 09-19-2010, 08:23 PM   #1
hotrodwolf
hotrodwolf's Avatar
hotrodwolf is on a distinguished road
Any advice before i start clear lexan tails?
Well, i have a lot of extra lexan that wasn't needed from my dads factory, so i'm gonna try my hand at forming it to a tail light lense. Any advice before i start would be great. ie- best mold or forms. ways to bend. heat to use. also what sealers will work best to attach it?
"How did you MELT the spark plugs!?"
hotrodwolf is offline   Reply With Quote
Old 09-19-2010, 08:31 PM   #2
hok666
hok666 is an unknown quantity at this point
Ive read on hear somewhere to use a oven in the process, but that's up to you.
hok666 is offline   Reply With Quote
Old 09-19-2010, 09:59 PM   #3
guiguilandry
guiguilandry's Avatar
I think that if you put in the oven the original rear light assembly with the lexan on top of it it will form itself to the exact waves that you need but I don't know what temperature to use nor how much time... i say go from 350 and wait that it bends itself to the desired shape... then get it out so it hardens in the good shape... that will be trial and error i think... for the sealer get clear caulk that resis UV rays
Custom or Nothing...
www.demonautosport.ca
Old 10-01-2010, 01:03 PM   #4
hotrodwolf
hotrodwolf's Avatar
So, i'm having trouble removing the original lens from the housing. Anybody done this before? I baked it at about 180 degrees like what you would do for the headlight, but no luck. It's still on solid. I tried to pry a bit and immediately broke a small corner edge.
Old 10-01-2010, 01:07 PM   #5
i'm pretty sure it doesn't come out. it needs to be broken and custom formed.
I'd probably do a clay mold of the outside of lens of the light. Then mold lexan to the inside of that clay (so its the same contact surface as the outside of the light)
but i know NOTHING about doing this kind of work.
Old 10-01-2010, 01:09 PM   #6
hotrodwolf
hotrodwolf's Avatar
It looks like it needs to be broken out to me as well. Thanks. The clay mold sounds like a good idea too.
Old 10-01-2010, 04:28 PM   #7
hok666
do it i want install pics, or i should say the process in which you are about to undertake....
Old 10-01-2010, 06:18 PM   #8
Taillights are not like our headlights. You have to cut the lense out! It's plastic welded or whatever you wanna call it.
Old 10-01-2010, 06:19 PM   #9
Also you will need to make a mold if the light first. Otherwise it will not line up cause the lexan will actually be bigger then the oem lense.
Old 10-01-2010, 06:28 PM   #10
^you just repeated what was said previously
Old 10-01-2010, 08:11 PM   #11
Heh sry I skimmed lol I'm guilty!
