Old 09-28-2006, 09:31 PM   #1
Removing Manual Window Crank
Got my 6x9 Pioneers installed, sound great, but I'm having a little trouble installing my new 4x6s. Can't get the manual (non-power) window handle/crank to come off so I can get the door panel off.
Searched through the forums, found that there's supposedly some clip on the shaft or something that when using the right tool it unclips it so it slides right off, but you know what, I see no clip whatsoever on the shaft or anything but a simple plastic handle on a metal shaft. What's holding it on, I do not know. The images in the thread Naich posted regarding removing the door panels for manual windows are broken so I don't even know what I'm looking for.
Any pictures of what needs to be removed or what needs to be done to get the darn window cranks to come off would be greatly appreciated.
Old 09-28-2006, 09:41 PM   #2
megabyte
megabyte's Avatar
megabyte is an unknown quantity at this point
It's a small clip that looks like this:
and it's located on the handle like so:
What you have to do is try to push one of the ends of the clip with a screwdriver. I've also read that you could try to slide a small cloth between the handle and the door panel so that it gets caught in the clip and then you pull it but it seems kind of difficult that way. Just push the end of the clip with a screwdriver...
megabyte is offline   Reply With Quote
Old 09-28-2006, 10:05 PM   #3
Thanks so much for the visual. Tremendous help.
Old 09-28-2006, 10:29 PM   #4
01GrandAm
01GrandAm is on a distinguished road
Or you could go out and buy a $5.00 tool and make your life easy
http://www.cardomain.com/item/SOU87600
01GrandAm is offline   Reply With Quote
Old 09-28-2006, 11:40 PM   #5
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
why spend money when you can diy?
battistoni21 is offline   Reply With Quote
Old 09-29-2006, 03:30 AM   #6
Document ID# 580011
2004 Oldsmobile Alero
Window Regulator Handle Replacement - Door
Tools Required
J 9886-01 Door Handle Clip Remover
Removal Procedure
Note the position of the window regulator handle with the window in the full up position.
Remove the spring clip by inserting J 9886-01 between the regulator handle and the bearing plate.
Pull outward on the regulator handle in order to remove the handle.
Remove the bearing plate from the door trim panel.
Installation Procedure
Position the window to the full up position.
Install the bearing plate to the door trim panel.
Install the clip to the regulator handle.
Position the regulator handle to the noted position.
Install the regulator handle, pressing into place until fully seated.
Document ID# 580011
Old 10-01-2006, 08:32 PM   #7
That little tool got it off in less than a second.
Thanks everyone.
