01-12-2006, 05:04 PM
Defeat < Giving Up
Ok so here's my problem,
On the way to a town that is about an hour away, my car just starts jerking back and forth, then it starts sputtering off and dieing, then it dies and i lose power steering......... I pull over sit for a second, and try to restart it..............it starts, i drive about a few miles down the road same problem happens again.
When i get to the college, i go in and register (car is obviously off this whole time) Come out an hour later and drive a Pretty good way on the way home, it starts doing the same excact thing.
Any ideas or leads i could look for.
3.4 v6 stock engine
WhiteLiquid
01-12-2006, 06:40 PM
AutoCross Alero
how long has it been since you changed your fuel filter?
01-12-2006, 06:45 PM
Defeat < Giving Up
the car has 57000 miles and i have owned it for 5 months never been changed under my ownership, idk about previously.
I thought about that, but is that really a possibility, cuz it would only run good after sitting a while
Thx for the advice
any more ideas greatly appreciated
WhiteLiquid
01-12-2006, 08:24 PM
AutoCross Alero
its quick cheap and easy to change, shouldnt take more than 30 mins.
01-12-2006, 09:03 PM
That's if it hasn't already trashed the fuel pump, our fuel pump/sending units are expensive,cheaply made junk...just ask Ken. Ever since his experience, I've been chaning mine once a year religiously.
01-12-2006, 09:07 PM
Defeat < Giving Up
Yea i might change them both out, Sucks because of the $$$$$$$ :alcoholic: but i might as well :Noooo:
WhiteLiquid
01-13-2006, 01:58 PM
O yea, the clogged fuel filter caused so much pressure build up that my fuel pump hoses broke off that was spraying around inside my gas tank.
Every 2 years or 24,000 miles, change that fuel filter
01-13-2006, 03:15 PM
that is the fuel filter for sure and possibly the pump. thats exactly how my gf's cougar drove with a bad filter.
01-13-2006, 04:49 PM
Defeat < Giving Up
I changed my fuel filter, it is still doing the same thing, i took it to a local shop, and they said they would drive it and see what they thought. They said either fuel pump or ignition module( )
How much $ is a fuel pump
WhiteLiquid
01-13-2006, 05:37 PM
the fuel pump is expensive.......a few hundred i believe and expensive on labor........
01-13-2006, 05:45 PM
Defeat < Giving Up
oh great
But hey its gotta be done, so i guess i'll just get it done and then party afterward :alcoholic:
WhiteLiquid
01-13-2006, 05:59 PM
Do your gauges go crazy at all when it happens?? I'm thinking something electrical.
CAI - Borla Cat-back - S&S Headers - DHP - AFPR
01-13-2006, 06:50 PM
Defeat < Giving Up
nah guages stay regular until the engine dies,
WhiteLiquid
01-31-2006, 10:55 PM
Defeat < Giving Up
:shout: issed: :shout: AAAHHHHHH!!!!! issed:
It was running fine for a while, and all of a sudden today on the way home from school same problem occurrs(see first post)
What the crap am i looking for here, I have no idea whats up.
SPark plugs--?
fuel pump---?
WhiteLiquid
01-31-2006, 11:10 PM
Defeat < Giving Up
does no one know
WhiteLiquid
01-31-2006, 11:55 PM
Best bet if you can't easily pinpoint it is to take it to a reputable mechanic. It's going to cost you but its easier to just bite the bullet once and get it over with. Let them do the figuring out, plus it will be fixed and you will not have to be angry about it anymore. It could really be a lot of things that are causing it and I don't see it being resolved on this forum. You will most likely just waste lots of time and money guessing and throwing parts at it. I've been through this a few times on my Alero and I know what your going through. It can be one of the most frustrating things to deal with especially if you use your car a lot. Good luck and let us know what you find.
01-31-2006, 11:59 PM
what would explain the power steering loss?
White, when yo usay surging back and forth, how does your transmission act? normal, relentless? wacky?
and what about your RPM's? this could be other things than the fuel filter....
AUTOBOT
02-01-2006, 12:02 AM
Loss of powersteering is likely because the engine is partially stalling out and not turning the pump.
02-01-2006, 12:03 AM
Defeat < Giving Up
the back and forth jerking comes from the loss and gain of acceleration(if that makes sense)
The rpm's slowly decrease
The power steering goes completely out after the engine slowly cuts out and dies off
WhiteLiquid
02-01-2006, 12:09 AM
Two main causes of an engine stalling are, loss of spark or loss of fuel. Those are the 2 main ingredients in detonation (other than air). So a place to start would be to have your fuel pump tested as well as coil packs and wires. Though, from your symptom, if the engine is completely stalling out, then I would less suspect it being wires or plugs or coil packs. Coil packs run 2 cylinders and if you have a bad coil pack, your still going to be running on 4 cylinders, so it shouldnt completely stall out. Same deal with a bad plug(s) or bad wire or two. A loss of fuel however would indeed bring down all 6 cylinders....Something to ponder.
