Hard Start/No start condition
Hey guys been a while since ive posted, Im having a problem with my wifes 1999 Alero 3400. Every once and a while after warming it up about 5 minutes then turning it off to go to the store or whatever. I come back to start here up and it cranks like its wants to fire up, but no start, you push on the throttle then it dies, you just here the starter running. It takes about 6 tries until it finally starts up without stumbling like there was no problem at all.
So far ive replaced the plug wires, spark plugs, evap purge solenoid, tps, iac valve, iat, maf sensor, new lim gaskets and upper plenum and throttle body gaskets plus cleaned all the gunk out. All my hoses are good no cracks sprayed car cleaner around engine bay and no change in idle.
When it decides to crap out on me I hear the fuel pump humming each and everytime i turn the key forward, crank here up and it just cranks like she wants to but then notthing.
This is ticking me off Im thinking it might be the ICM or a bad coil but im not certain. Thinking about heading down to oreillys to getting the ICM checked. I nothiced that fuel tank charcoal canister has been smelling like fuel lately dont know if that would be the problem.
What do you all think or has this ever happened to anyone.
The problem is not all the time just like every other day and its ticking me off.
1999 Alero 3400
Just hit 210,000 miles bisches
