Old 04-13-2009, 08:00 PM   #21
WhiteV6
Wide Open Throttle
WhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond repute
Head gasket is blown and the pressure is building up in the cooling system from the combustion process.
Ben
WOT-Tech.com
60DegreeV6.com
WhiteV6 is offline   Reply With Quote
Old 04-13-2009, 08:05 PM   #22
c.r.s.
c.r.s. is on a distinguished road
Here we go!!
c.r.s. is offline   Reply With Quote
Old 04-13-2009, 08:39 PM   #23
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
Originally Posted by c.r.s. View Post
Came home from work @ 6:00PM Filled the Coolant reservior (w/water) and started the engine to look for leaks again (I'm blind as a bat) the water was coming out of the coolant reservior over flow hose and spraying onto the tensioner and crankshaft pulley's with in 1 minute of run time.
There must be blockage in the coolant pathways in the engine.
The engine idled roughly for about 3 minutes then it was running smooth.
Water was dripping out of the tailpipe within 4 minutes.
Turned the engine off (let it cool for a bit) started looking for leaks on the rear head at the head & intake gaskets no leaks. Ran my hand over these areas, everything was dry.
Looks like its time to remove the intake for further inspection, ARRRRG !!
Sounds like I'm on the way to a Valve Job, Head Gaskets, Intake Gaskets.
Let the fun begin,
Thanks for your help,
Good luck and get the new lower intake gaskets from fel-pro...i installed them onto a 3400 and they worked great..
A57 is offline   Reply With Quote
Old 04-13-2009, 09:20 PM   #24
same, gaskets are great
