06-27-2011, 07:19 PM
Help!!! Brakes
Ok so i replaced all my brake lines so now i have to bleed them out.. So the front passenger side and the rear driver side bled out with no problems at all.. But the other two just wont bleed properly,theyre all bubbly and stuff.. If anyone knows what could be causing this or how to fix it then that would be greatly appreciated
Thanks
99 alero
Pioneer stereo
Low budget
Mesh grille
2 12 inch pioneer subs
10 inch class D bazooka tube
06-27-2011, 07:21 PM
you sure you're keeping the reservoir full during the entire process?
i like using the vacuum bleeder, just sucks it all out by itself and all you have to do is keep the reservoir full
06-27-2011, 07:39 PM
Keep the brake pedal down and the bleeder valve open, it will come out
06-27-2011, 08:02 PM
did you start bleeding on the brake farthest from the master cylinder?
06-28-2011, 07:09 AM
how about this. in detail how do you bleed your brakes?
06-28-2011, 08:25 AM
So to bleed them i put in all fresh brake fluid and then i had my brother open the valve while i was pushing down slowly.. Then i just held it down for anwhile tightened the valve and repeated that process.. I went from the farthest caliper away to the closest.. And i may rent a vacuum bleeder
99 alero
Pioneer stereo
Low budget
Mesh grille
06-28-2011, 08:33 AM
have your brother pump the brakes (with the bleeder CLOSED) then hold the brake on, while hes holding the pedal to the floor then you open the bleeder and close it. tell him NOT to let off the brake until you have the bleeder closed again, repeat on every caliper until brakes have pressure again..
06-28-2011, 09:01 AM
agreed. try that before you do anything else and see how that works.
06-28-2011, 11:21 AM
K thanks ill try that
99 alero
Pioneer stereo
Low budget
Mesh grille
06-28-2011, 12:57 PM
oh god this has disaster written all over it. if you dont know what your doing with something that is important as brakes please for the sake of innocent people on the road take it someone and have a professional do it.
06-28-2011, 01:59 PM
x2 if you have air in your lines you will not be able to brake as well. Then you put other peoples lives at risk. i am glad you are trying to do it you self. make sure there is enough brake fluid in the brake reservoir. This is a two person job. Someone has to be in the car pressing on the brake peddle. You have to start from the farthest from the master cylinder. but if you need help do not be afraid to ask someone. Plus be very careful with the bleeder screws they can be rusty and can break. Then you will have to get a new caliper. If the bleeder screw is stuck used some wd40 or PB blaster so it makes it easier to take loosen.
07-01-2011, 09:40 PM
X3, unless you have been shown "how to" by a pro and are very comfortable with the job, this one you need to spend a few bucks on and have the pro's take care of the bleed. Hell, you have already saved a good penny on labor installing the lines yourself!
