did this JUST happen after the tune up?
if so, double check your gaps on your plugs, you did gap them to .060 right? please say you did and you didnt just take them out the box and put them in.
if you just took them out and put them in, i would bet at least one plug is not gapped right.
if you did gap them right and the SES light just came on, there is something wrong with what you did, double check your stuff again.
if the light was on before you did the tune up, you MIGHT have a bad coil pack OR a bad PCM inector driver. i wouldnt say its the fuel injector just yet, but if it is, i got a couple hookups on some injectors for fairly cheap.
