10-07-2009, 03:01 PM
Fi BL 12" in a 3.9cubic ft box. cheggit!
Officially addicted to bass.
10-07-2009, 03:27 PM
Box looks killer, what's the depth on the port?
Can you make up an LED system to use instead of the bulb?
10-07-2009, 03:33 PM
i have no idea about the depth of the port. ill illustrate how it works in ms paint the best i can (picture below) as for an LED light for it.. im not that skilled with LEDs lol
10-07-2009, 03:36 PM
I'd start with a 194-base LED. No work required.
10-07-2009, 03:49 PM
i had the same issue, not the light burning out, but the loud rattling..
If you stick like a flathead screwdriver in between that space, obove the plate, it prys down, and i put a piece of rubber weather stripping in it, and it stopped vibrating instantly. the piece was grey so i got some car touch up paint and matched it to the body.
hope that helps you, if you have questions just pm me. id be glad to help
10-07-2009, 05:04 PM
that is a nice sub and box
10-07-2009, 05:32 PM
I poop alot
3M double sided tape for that. And if you want I work on Home ave I have an extra LED 194-bulb.
10-07-2009, 05:51 PM
So thats where that box went.
Looks like you killed the carpet
Did you really put the speaker wiring right through the top of the box????
10-07-2009, 06:39 PM
x2, why? that kinda kills the purpose a lil bit of a good built box. buy a cheap $2 plate and mount it to the back of the box so its correct, and seal that hole in the op up good.
10-07-2009, 06:42 PM
Well put it on the bottom at least... lol
10-07-2009, 11:09 PM
well i've had my 18" in for a week now with the heavilly dynamat'd panel in the trunk lid and its not as loud, but i have noticed its getting really loose the plastic clips that hold that on wear out quick. i'de also recommend using a shit-ton of weather strip around any and all peices that come close to each other. the whole panel is easy to remove all u need is pliers to pinch the little plastic clips in theres about 8 total. then it pops right off.
10-08-2009, 12:24 AM
yeah i did kill the carpet.. furious box install @ 3am in the pitch black with trunklight + cellphone light. ill re-carpet it in the next few months.
as for the wires coming out the top... thats the way bwcad1 had it set up. thats the only place for the wires to come out and i dont have the tools to make a spot for a terminal
10-08-2009, 12:57 AM
And just silicone the **** out of the hole on the top...
Under construction...
10-08-2009, 07:46 PM
I poop alot
Hot glue is your best friend!
