Old 07-26-2010, 12:25 PM   #1
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
Phantom windows
Ok so for the past 8 months or so whenever the car would be on, if i just tap the drivers side window it automatically goes all the way down and it wont go back up unless you turn off the car, lock it, and put the key back in. so when i get in the vehicle, before i start it, i set the window where i want. (tap the button and turn the key off when it gets to its desired location) but as of yesterday, ill set it where i want, and after about 30 seconds or so it goes down all by itself. i dont touch anything whatsoever and it automatically rolls all the way down. pretty annoying in the rain. any ideas as to what the issue is here?
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 07-26-2010, 12:28 PM   #2
beats the hell outta me. bcm issue?
Old 07-26-2010, 12:30 PM   #3
widbyj
widbyj's Avatar
Switches or panel going bad. Remove from door, clean internals and re-install.
Old 07-26-2010, 01:04 PM   #4
MattismodderX
as in the connectors? how would you clean something like that. q-tips and rubbing alcohol?
bcm?
Old 07-26-2010, 02:21 PM   #5
The BCM has noooothing to do with the power windows.
It's the "express down module" almost 100%... a small solid state computer module attached to the driver's side window switch.
Buy a new full driver's side window switch assembly and you should be good to go, can't fix this.
Old 07-26-2010, 02:26 PM   #6
MattismodderX
where would you find something like this? besides a junkyard
Old 07-26-2010, 03:56 PM   #7
...and now i know.
...and knowing is half the battle.
see if someone has a part out going, that has switches?
Old 07-26-2010, 04:35 PM   #8
Philbar71
Rock auto has them. But their super expensive if you have a 4 door. I would try your local junkyard first.
http://www.rockauto.com/catalog/x,ca...,parttype,4624
Old 07-26-2010, 05:50 PM   #9
...and now i know.
Wiring diagrams FTW, I didn't know either until I pulled one up
Also, Ebay. http://cgi.ebay.com/ebaymotors/2001-...fAccesso ries
