Old 01-03-2008, 09:15 AM   #1
JCHT79
JCHT79 is an unknown quantity at this point
Send a message via Yahoo to JCHT79
No Power Steering/Loss of all fluid and no pressure!
I just woke up this morning and tried to steer my car out of the driveway only to notice a cracking sound and or a sound similar to the one associated with the wheel hub assemblies when they go bad. I sopped my car, got out and looked under the car to see power steering fluid leaking out. Does anyone know how costly it ca be to repair the power steering? For now I've got a good mechanic/friend coming to check my car out this morning. I'll post more later as I find out.
Thank you weatherman for the coldest winter day of 2008 so far in the Northeast NYC area.
Orig Date Joined: 23-MAR-2003 (before re-registering!)
Orig # Of Posts: 17
1999 Auburn Mist Sedan
No Extras!
JCHT79 is offline   Reply With Quote
Old 01-03-2008, 09:45 AM   #2
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I can almost gaurantee that it was frozen and expanded so much it caused to to leak.
Old 01-03-2008, 09:50 AM   #3
misslindseysue
MINIac
misslindseysue's Avatar
misslindseysue is an unknown quantity at this point
Send a message via AIM to misslindseysue
At one time I was told ~$400 for a re-man rack, then labor. If it's just the reservoir, I'd guess a lot less.
Lewis said it was 0 deg in the neighborhood, all the way up to 2 on the freeway this morning. BRR!!
misslindseysue is offline   Reply With Quote
Old 01-03-2008, 09:58 AM   #4
it was cold enought that the cheap clamp they use from the factory to hold the hose on didn't hold. Look at the hoses, see if one is off, then just put it back on with a real hose clamp and fill it up. Hoses coming off in cold weather are a very common problem with any vehicle in the cold.
that sounds pretty good right now, were having 25-35 below wind chill here. good weather other than that tho
Old 01-03-2008, 10:33 AM   #5
AtomicX
AtomicX's Avatar
Cost me $400 for parts and labor when I had to replace my power steering pump.
Old 01-03-2008, 10:50 AM   #6
wow
$175 and a half a day in my driveway
Old 01-03-2008, 10:59 AM   #7
JCHT79
I can't see any clamps that would lead me to beleive its just a hose, but the area the power sterring fluid is coming from is underneath inbetween the front L/R wheels and I can't see anything else.
Orig # Of Posts: 17
No Extras!
Old 01-03-2008, 01:44 PM   #8
AftermathAlero
Originally Posted by YALEROYNOT View Post
wow
x2!
easy to change out! well not half a day for me.. like 30min to 1 hr.
If your doing it yourself, you will need to buy the power steering pump pulley tool. It will install and remove it. Can be found at autozone. Don't get one from oreilly, theres is only the pulley remover. But you can also rent the tool too at autozone instead of buying one. renting just need a deposit, buying the tool is like 15-20 bucks.
Old 01-03-2008, 02:30 PM   #9
JCHT79
Thanks. I just found out that the hose underneath running near the rack is completly destroyed. The new hose plus labor and tax is running me about $250.00 +/- a few dollars.
Orig # Of Posts: 17
No Extras!
