04-29-2007, 11:12 PM
#21
who are you to act like you know it all.. your the one that cut your cat out lmao. thats ridiculous.....
anyways i like the look of your exhaust but dual 40's would be waaaayyy overkill on my 2.4L i think. i havent decided on my exhaust at all... i want dual tips to go with my razzi but i want a mild effect. i have no clue =(((
04-30-2007, 08:42 AM
#22
^ put a flows 80 ... should be good with the 2.4
04-30-2007, 10:55 AM
#23
This summer I am going to be putting a new exhaust on my car what would be a good one for my 2.2?
It's not green It's Dark Tropic TEAL
05-01-2007, 09:33 AM
#24
I love the dog.
"If the author of the Declaration of Independence were to utter such a sentiment today, the Post Office Department could exclude him from the mail, grand juries could indict him for sedition and criminal syndicalism, legislative committees could seize his private papers ... and United States Senators would be clamoring for his deportation that he... should be sent back to live with the rest of the terrorists." - Frank I. Cobb
05-04-2007, 02:07 AM
#25
Originally Posted by pawzbear
who are you to act like you know it all.. your the one that cut your cat out lmao. thats ridinkulous.....
if your state didnt have emmision checks you would have yours cut too im sure. besides sweetnlow always has a negative comment about everything
3400 V6
05-04-2007, 02:20 AM
#26
I wouldn't. I like being able to start my car in the garage and not have it reek. And just because your state doesn't have emission testing doesn't mean it's LEGAL to remove the converter.
05-04-2007, 04:09 AM
#27
i wanna see some dyno numbers backin this cat removal
05-04-2007, 04:29 AM
#28
Southern Fly Boy returns
the welcome mat is for when he throws his mangled dead corpses in the trunk haha
05-05-2007, 01:03 AM
#29
Defeat < Giving Up
Nice tips....I have the same ones.
WhiteLiquid
05-05-2007, 06:48 PM
#30
Boost Guru
It was in a magazine a few months back. A test on a car that had an intake and cat-back exhaust already on it. If I remember correctly, first run they made with the stock cat, second run they made 5-8 more hp with a high flow cat, third run they made 1 more hp than the high flow with no cat. So you have to decide whether you want 1 more hp out of your setup or be street legal. There's no question in my book, I'll take the high flow cat any day.
05-05-2007, 07:42 PM
#31
V.I.P. Punching Bag
or where im at, i can remove the cat and get 6-9 HP more and still be legal
05-05-2007, 07:43 PM
#32
absolutely spilner. And sats, you could do that, or do high flow and not have your car reek and know that your arent contributing to destroying the environment. And the resonator is a restriction, yes it is straight through but its that expansion chamber to change the exhaust not that significantly reduces exhaust velocities. I dont have any quotes to back that up but i thought it was just commonly understood, the same way that an overly huge exhaust causes issues.
05-06-2007, 06:20 PM
#33
WOW have you seen a resonator. Obviously not and no our cat does not flow well take it off and see for yourself. I am catless and love it I cut the resonator off and stuck it back on because its basically a straight pipe with a baffle around the inside. So no the restriction is NOT in the resonator.
"An exhaust resonator is used in some exhaust stystems to CHANGE THE TONE and timber of the exhaust sound. The resonator helps reduce the annoying vibrations of exhaust gas pulses with a length of perforated tubing inside an expansion chamber. The exhaust gasses partially escape the tubing diameter through the perforations into the expansion chamber. In the expansion chamber, the exhaust gasses expand and change tone. When the gasses re-enter the tubing, they rejoin the exhaust flow and dampen the vibrations of the combined flow, creating a more pleasing sound." BMWE34.net SO IT IS BASICALLY FOR SOUND PREFERANCE NOT FLOW RESTRICTION
have you ever seen the resonator of a N-body?
joelsoundxtreme: u faggot
05-07-2007, 12:09 AM
#34
Wow, you live in like one of 3 provinces with no legislation for emissions... That's some crazy stuff!
05-31-2007, 12:35 AM
#35
ok enough said, if your going to go with a different setup on ur cat, go high flow, why bother being illegal for one horse. besides it is kind of an a-hole thing to do the the environment when it can be fixed so easily with virtually NO CHANGE in performance.
