02-20-2009, 11:20 AM
Redesign Photoshopping
I need someone with photoshop and some free time.
the majority of my interior is pewter. the rest is taupe. I've been debating as to how i should change the taupe color. I'm still not sure if i will or not, but i'm just getting some ideas now.
Since i have two new doors to play with, i have the opporunity to take them apart and revinyl them (don't have to dink w/ dyes)
First question... is how? i see these plastic rivet things... which you can drill out. but how to you get them to stay together again, once you do that? I'm totally lost at that point. (i'd want them together as tight as they are now. rattling drives me nuts)
Secondly... This is where i need a photoshopper. I want a good color scheme. I'm thinking Pewter and Black with Red (or blue) backlighting. Now... do i want to change the taupe to pewter then have black accents, or leave the pewter where it is, and change the taupe to black?
For the doors, i was thinking doing black where the taupe is, pewter speaker pod, pewter plate/door handle/suede fabric insert
heres some pics for you to play around with(of varying sizes). feel free to post up something original. Even though i may not use it... someone else might.
last two are of the front and back of the door. (same area) i've seen people remove this, and recover it... how to you get it to stay on again, after the "rivets" are drilled out?
02-20-2009, 11:38 AM
plastic rivets
02-20-2009, 11:40 AM
drive to texas and have richie wrap 'em in suede.. id photoshop them for you however i dont have photoshop anymore and im having a hard time finding cs4 :\
02-20-2009, 11:42 AM
um.....the point of this is he wants to do it himself.
02-20-2009, 11:50 AM
i'd LOVE to have richie do it. but TX is too far, and i'm sure it costs too much. in comparison
If richie sees this, feel free to share some tips from an expert.
a very rough cut of the door... at least each piece is in layers now.
http://depositfiles.com/files/j0vhpcmcf
02-20-2009, 12:57 PM
very poorly done... (i suck w/ photoshop)
but...
....meh... not so sure i like the looks of it... someone please come up with something better. (i know it hasn't been very long.. i plan on having patience w/ this... i'm in no hurry)
02-20-2009, 01:29 PM
downloading photoshop nao.. you for sure need some more practice in photoshop lulz
02-20-2009, 01:45 PM
i'd rather have other skills... no need for these, i know people to go to for this stuff.
02-20-2009, 02:45 PM
02-20-2009, 02:49 PM
by "backlighting" i mean i have led projects that i do, that will illuminate certain areas at night.
i'm kinda torn between having the door black, and the top gray, or vice versa... hmm
thank carcrazy... MUCH nicer then mine.
02-20-2009, 02:52 PM
Illuminate the bases of the doors, so that when you open the door LEDs light up! Wire it to the cubby light.
And 1000 posts!!!
02-20-2009, 03:11 PM
Put a light behind the door handle, the map pocket, and maybe behind the speaker mesh. Might look alright.
02-20-2009, 03:26 PM
I wonder if anyone as ever light there windows up so that the light travels throught the glass?
02-20-2009, 03:35 PM
That sounds like it would actually look pretty cool...
02-20-2009, 03:53 PM
me and yalero were toying with the idea... then his car fell apart. so next time i rip mine apart, i'll find out.
put some leds under the bottom of the window... see if the whole window tints to that color. i hope so... pretty sweet. (although... i hope it doesn't fade the color. i don't want pink windows)
i won't have the map pocket (which i currently have lights in) so i hope to move to lighting up the speaker i'm installing. gotta play with that. i plan on doing the handle and switches.
02-20-2009, 03:54 PM
I think an all black interior like the trans ams had would look nice
Have a good day
02-20-2009, 10:33 PM
Originally Posted by CaRcRaZy
kinda liking that... just need the taupe pieces to be similar gray as the top portion....
...and if someone wants to photoshop a door pod on there.. feel free. i won't have those map cubbies on there anyway.
but at the same time.... w/ the bottom black, and top gray... what color do i use for the center fabric part?
02-21-2009, 01:55 AM
I really like the 3rd one from CarCrazy. Looks like it could have come like this from the factory
02-21-2009, 07:27 AM
definitely torn between those two. thats for sure.
02-21-2009, 11:26 AM
Si vis pacem, para bellum
thats insane, i personally like the 2nd one, makes me wanna go rip my doors apart right now and do this lols
After you party naked.... always go to the nearest clinc afterwords....
