Old 02-16-2008, 06:12 PM   #1
dbailey
dbailey is an unknown quantity at this point
Pulley or Belt???
Got a squeak that goes away for a short time when I hit it with belt dressing but it comes back within a couple of minutes. Goes away most of the time after I drive awhile. Belt or pulley? Anybody ever had this problem before? I have the 3.4 V-6. Thanks guys.
dbailey is offline   Reply With Quote
Old 02-16-2008, 06:17 PM   #2
jaybs02
jaybs02's Avatar
jaybs02 is on a distinguished road
Send a message via AIM to jaybs02 Send a message via Yahoo to jaybs02
Belt
"J"
02 Bronzemist Alero
DetailCity.org - Supermod ... Join the obsesion
jaybs02 is offline   Reply With Quote
Old 02-16-2008, 07:15 PM   #3
dbailey
That's kinda what I was thinkin. It's been awhile since I replaced it. Would a belt be noisy when you first start it and then quieten down after it warms up?
Old 02-16-2008, 08:46 PM   #4
CharleyO99Alero
CharleyO99Alero's Avatar
CharleyO99Alero is on a distinguished road
Yeah, that can happen. Look at the belt and if you can see cracks in the belt or it looks worn, replace it soon so that other parts are not effected when it breaks.
CharleyO99Alero is offline   Reply With Quote
Old 02-18-2008, 10:24 PM   #5
99oldsalerogls
99oldsalerogls is on a distinguished road
water pump also makes high pitch noise's if you have noticed any coolant leaks also
99oldsalerogls is offline   Reply With Quote
Old 02-18-2008, 11:35 PM   #6
DOHC_tuner
DOHC_tuner's Avatar
sorry but i have the 2.4 and i would also spray some belt dressing on it and it would come back after a while so I just replaced the belt although when I replaced my alternator too, the pulley squek. did i confuse you
Old 02-19-2008, 11:39 AM   #7
WhiteV6
Wide Open Throttle
I had a squeak, and my tensioner pulley ended up melting around the bolt. Glad I was in my driveway when I smelled it! its probably the belt, but I would check the pulley for play and grinding.
