Old 09-17-2011, 03:10 PM   #1
sponge
sponge's Avatar
sponge is on a distinguished road
Unhappy power steering return hose failing for the 4th time
in about roughly 7,000 miles, i have been through 3 return hoses and the current one is leaking bad the steering gear itself is new along with the pressure hose. i always bled the air properly from the system. does anyone know whats going on?
sponge is offline   Reply With Quote
Old 09-17-2011, 03:13 PM   #2
Poor quality hose? Not hooked up right? Using stock style clamps and not worm type?
Are you sure it's the hose and where is it "failing"
Old 09-17-2011, 03:19 PM   #3
sponge
sponge's Avatar
i've used two different brands now, it usually fails where the rubber meets the steel part. i've even tryed just using different clamps. i also tryed adding an extra clamp. didn't work.
Old 09-18-2011, 01:53 AM   #4
Isn't the hose threaded into the pump?
I never did a PS pump on an Alero, just old school GM cars and the hoses were threaded into the pump and the steering box
Old 09-18-2011, 02:10 PM   #5
sponge
sponge's Avatar
it's threaded on the steering gear and clamp on the resevoir, the pressure is hose is threaded at both ends.
Old 09-21-2011, 02:24 PM   #6
zzyzzx
zzyzzx's Avatar
Was the new one made in China?
Old 09-21-2011, 03:18 PM   #7
Dobbie
Dobbie's Avatar
Dobbie is on a distinguished road
Sounds like you might have a bad engine mount or something because if it's failing where the rubber meets the steel means it has way too much play there.
2003 Alero 2.2 Ecotec Auto - Cosmo intake - cleared/painted headlights
Dobbie is offline   Reply With Quote
