05-03-2010, 03:04 PM
The Aleromod PITA
knocking
hey so i stop at a gas station put the car in park and cut it off. when i take my foot off the brake she lurches forward and like catches on the gear of somthing kinda like a manual rolling backwards when you taking off on a hill.
then i start her after getting gas and theres a knocking sound, i rev it alittle and it goes away, but the noise returns as she goes to idle, on the highway she ran fine except for some more odd idleing a red light.
the knocking sounded like metal on metal, but more a scuffing then a clashing
05-03-2010, 07:21 PM
my autos always rolled a little on a hill before they stopped moving, it just catches. i believe that's fairly normal. (i can't compare to mine since i'm a standard, sorry)
as for the knocking. what year of alero is it. because the 2002 ecotecs had oil pump problems with oiling the timing chain. so maybe things aren't getting oiled properly. (i believe thats how i blew my motor)
and check your oil, be sure it's full. and my alero kinda ticks while idling, it's not really loud, but it's there. maybe a video would help
sorry i can't be more helpful alerodrime. and i'm not a expert, so hopefully someone who knows more will help you out. i'm still trying to learn about these motors
05-03-2010, 09:00 PM
The Aleromod PITA
it does it on hill but this was a much bigger lurch and was on a level surface, thats what surprised me
05-03-2010, 11:53 PM
Is this a one-time occurrence or continuous?
05-04-2010, 03:07 PM
The Aleromod PITA
so far one time sunday night, the cars been parked since, i just checked my oil, its a lil full but the cars facing downhill.
it was involved in an accident two weeks ago with a mailbox but i havent seemed to have any issues from that
05-04-2010, 11:30 PM
Canada's Ghost
possible exhaust leak... the exhaust leak on my dads truck sounds almost like knocking.
05-04-2010, 11:50 PM
do you have the appropriate amount of oil in it?
05-05-2010, 09:32 AM
See if it happens again, could be just a fluke.
05-05-2010, 01:54 PM
The Aleromod PITA
5 quarts, maybe a lil less, but i started her today, the knocking wasnt as audible but there was a gurgleing for the first few seconds, i put her through the gears, didnt hear anything odd, im gonna put the car in the air with weekend and check the pan, i should get tags on my celica this month, so i can park her and check her out
05-10-2010, 02:23 AM
05-10-2010, 03:12 AM
i know the 3400 is 4.5q oil, the 2.2 is 5q? you should really only fill it to the required level anything more is bad.
05-10-2010, 03:36 AM
idk i always about 5 qts in my eco
05-10-2010, 09:44 AM
same
05-10-2010, 03:24 PM
Canada's Ghost
meh who knows what it really is, if and when my L61 starts knocking I'll pull the engine out and build it from the ground up cause it seems like a great excuse to build the engine
05-10-2010, 03:29 PM
yeah the eco definitely takes 5 qts
05-10-2010, 05:08 PM
word. im just waitin for mine to die on me im tired of workin on hondas, i wanna rip apart my eco
05-10-2010, 07:51 PM
mine might be the first to go. found a chunk of metal in my oil pan last oil change
05-10-2010, 08:12 PM
i always put 5qt in my 3400. why not? its just going to lubricate more. its not like your putting 6-8qts in. another half isn't going to kill it.
05-10-2010, 10:08 PM
Canada's Ghost
Since I cant find a s/c set up at the moment I'm going to buy a ecotec block to tear down and build over a longer period of time, then say screw the S/C go with a snail and boost the snot out of it and see how well a sleeved and forged ecotec holds up to what I throw at it, chances are my transmission will not want to be part of the fun.
05-10-2010, 11:28 PM
You got an auto?
