Old 03-10-2015, 08:33 PM   #1
Silver SLP
Silver SLP's Avatar
Silver SLP is on a distinguished road
No start, no radio condition
My car started just fine leaving for work this morning and then coming home. I went to move my car out of the garage this evening, and the starter wouldn't engage, nor would the radio turn on. I heard the fuel pump prime, but my chimes were non existent, the radio wouldn't turn on, my gauges wouldn't move (fuel or temp), and the only light on the dash was the SES but no codes were thrown. The starter just wouldn't engage. I do have an aftermarket radio but have never had any problems like this in over 3 years. Passlock has been disabled as well.
I pulled the radio fuse (passenger side panel) and put it back in. Immediately I heard my chimes cycle. I tried to start the car and it started right up.
Anyone have any ideas what it could be?
2004 3.4 V6 - 105k mi. - Jan. 2015 AOTM
Silver SLP is offline   Reply With Quote
Old 03-10-2015, 11:42 PM   #2
When mine did something like that, it was the battery.
Check your trip odometer, was it reset?
Old 03-11-2015, 01:22 AM   #3
Nas Escobar
Nas Escobar's Avatar
Check your battery terminals and battery itself (as in take it to your local parts store for testing).
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Old 03-11-2015, 05:21 PM   #4
^^ Yes, could be a loose ground connection at the battery
Old 03-11-2015, 06:27 PM   #5
Silver SLP
Silver SLP's Avatar
Trip odometer was not reset. Will have the battery tested. Thanks for the suggestions.
Old 06-07-2015, 10:41 PM   #6
Nman
Nman is on a distinguished road
I also back the bad ground, There is a splice pack right were the starter is and if it isn't grounded none of the cluster gauges work and the starter doesn't engage. Does it 'tick' when you try to start it? Also if not does the check engine light come on when you turn the key all the way over?
Nman is offline   Reply With Quote
