Right side speaker problem
I was hoping maybe one of you have encountered this before or know a solution.
Basically, I just switched out the stock door speakers a few days ago for some new pioneers, wired and soldered, everything was fine. The past few days though, I noticed I was only getting sound from the left side of the car and the bass in the back.
The most confusing part, is that the tweeter on the right still works, though it's wired through the door speaker that doesn't. The right speaker in the back is still stock, but it hasn't been working either. The sub doesn't work when panned to the right.
As far as I know, all wires are taped up nice where they need to be, and everything is connected as it should be. I pulled out the deck and made sure all the wires were tight and connected from the amp install, and they were. Even if I blew the right side speakers though, wouldn't there still be some horrid noise rather than none?
:rage:
