06-16-2009, 12:36 PM
#21
Yeah, if you could get a known good one for cheap.
You did check all the fuses, etc.. for it, right?
06-16-2009, 12:56 PM
#22
Originally Posted by Colllin
how do u bypass the amp would putting in an aftermarket deck solve this
Yes if you run new speaker wire to all speakers.
06-16-2009, 01:03 PM
#23
You could just jumper the wires at the amp connector. If I remember right, the radio adapter harness will plug right in and you can jumper the appropriate wires.
06-16-2009, 03:21 PM
#24
I would try the radio first, and see if the internal amp in the radio itself took a dump. Just need to splice into any speaker pair and hook a cheap speaker to it. If it plays the radio is fine and the monsoon amp is dead. If you get nothing, you need a new headunit.
Off the Back of the radio itself:
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: (Class 2 Data)
Radio Ground Wire: Black/White
Radio Antenna Trigger Wire: Dark Green
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
One Bolt at a Time.
06-16-2009, 11:11 PM
#25
The Aleromod PITA
isnt there a fuse on most amps, check that fuse
06-16-2009, 11:20 PM
#26
06-16-2009, 11:29 PM
#27
The Aleromod PITA
is there a way he can see if sounds going to the amp, if its not going to the amp then the amps not the problem
06-16-2009, 11:41 PM
#28
Yes he can see little music notes dancing their way to the amp....lol u gotta see if power is running to it and out of it
06-17-2009, 08:40 AM
#29
06-17-2009, 09:27 AM
#30
if its the amp how do i fix it
Find one at the Junkyard. I've seen them (in a Grand Am).
06-18-2009, 02:40 PM
#31
The Aleromod PITA
take it appart maybe theres an internal fuse like with vcrs and what not
06-18-2009, 04:57 PM
#32
Nope Sorry, there is no fuse inside the monsoon amp, best bet is to go to a junk yard and find one in the back of a grand am or another alero, I have 3 of them at the moment, 2 found in the junk yard(haven't gotten around to testin them though) and the 1 currently in my alero. Or try what cliff just explained, and last but not least just install a new system(fun fun stuff)
Raz
Lets Flip A Coin...Heads I get Tail....Tails I Get Head
06-18-2009, 07:48 PM
#33
I have a 2004 stock radio im trying to get rid of for barely nothing other than to ship it if it turns out to be the problem.
06-19-2009, 05:39 PM
#34
06-19-2009, 05:55 PM
#35
hes obsessed with internal fuses =]
100,000 Mi 3/29/2011
06-19-2009, 11:08 PM
#36
