05-31-2009, 05:18 AM
Hey Ryan..
hey.. ryan im in need of some help.. just one night out of the random and ever since then my subs have been just humming whenever the radio is on.. even when the volume is at zero.. so im getting feedback to the subs from the cd player.. any ideas on how to stop this? this bass hum is really getting annoying and its been like this for about a week.. my guess is the radio cable might have a loose connection? the rcas are in just fine. any help would be great man!
05-31-2009, 05:26 AM
Adam,
It sounds as if you are running interference through your rcas. Try unplugging your RCAs and touching them to the tip of your fingers, you should get a little hum from them (caused by the electricity in your body). If not then you have the same problem I did, it is probably bad RCA's. I replaced mine and REGROUNDED my ground wires and everything went back to normal.
Of course this is just my two cets. Ryan is definitely the Guru to be asking.
-Smurf-
05-31-2009, 10:03 AM
Turn the radio on, pull the RCAs @ the amp.
If the noise is still there:
1) Try regrounding the amp
2) Its the amp
If the noise is no there
-Pull your RCA out and inspect for damage. Try a different cable also at this time.
If that doesnt solve it.
-How is your radio grounded? If its not brounded thru the stock wiring harness, find a new ground for it.
If that doesnt work
-Bad head unit.
05-31-2009, 11:10 PM
The Aleromod PITA
ryan, which do you recomend for subs in the 250 rms area, rockford or memphis?
05-31-2009, 11:40 PM
06-01-2009, 12:30 AM
Kitteh is back!!!!
Originally Posted by Ryan from Ohio
wow a sub with 93db....thats impressive with the subs out nowadays.
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
06-01-2009, 08:11 AM
Just a weaker motor and probably a softer spider...
The BL is fairly low.
06-01-2009, 10:46 AM
The AB DX series are amazing subs for how cheap they are. They impressed the hell out of me lol
06-01-2009, 01:36 PM
Considering a 12" DX is only $80 a pop you are spot on...
06-01-2009, 11:26 PM
The Aleromod PITA
i just bought the Memphis 10s i think they're whats called the power reference series, anyways they're dual 4 ohm, my amp is now bridged and 4ohm stable and its hitting so hard, the top of the trunk in almost literally bouncing, any ideas on what to do with that
06-01-2009, 11:43 PM
Yes.
Duct tape your girlfriend to it and let the bass flow.
06-01-2009, 11:59 PM
Wow, AleroRacing.
You asked a question, then completely ignored the advice. Enjoy your entry-level memphis, those AB subs are on a completely different level.
06-02-2009, 04:12 PM
turn down the volume if that doesnt work do what ryan said
06-05-2009, 10:21 PM
To adam337, do you have the cabin speakers ran direct to the h.u.?
