Old 06-25-2009, 06:42 PM   #1
Cashdollar2009
Cashdollar2009's Avatar
4 gauge fuse...
What size fuse would be appropriate for my 4 gauge power wire? I bought a kit, and i guess it came with a 60 amp fuse, which just blew. But searching all over the internet i have came up with a few 100amp figures??? ANy help please?
Under construction...
Old 06-25-2009, 07:00 PM   #2
how many watts are you pulling?
60A is ALOT. check your wiring.
Old 06-25-2009, 09:30 PM   #3
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
Woah.
60amps is the most I'd run on 4gauge. I got a feeling you were clipping the hell out of your amp or you had a DC short.
Fi-Alero is offline   Reply With Quote
Old 06-25-2009, 10:14 PM   #4
ryanJ
ryanJ's Avatar
ryanJ is on a distinguished road
how big are the fuses on the amp?
ryanJ is offline   Reply With Quote
Old 06-25-2009, 11:10 PM   #5
4 Ga is rated to 150 Amps.
The amplifier you are using will dictate what fuse you need up front.
For instance, if your amp has 80 Amp worth of fuse on it, you want to run a 100 Amp up front.
Remember the front fuse is ONLY there to protect your wire... Its not meant to regulate current to the amplifier.
Old 06-25-2009, 11:12 PM   #6
Originally Posted by Fi-Alero View Post
Woah.
60 Amps is the highest rating on 10 Ga wire.
Old 06-26-2009, 02:24 AM   #7
Fi-Alero
Fi-Alero's Avatar
Oh sh*t lol sorry, for some reason I was thinking 8-10gauge instead of 4 lol.
I usually rate the fuse for wire by the current that the wire can hold, since that is what you are protecting anyway unless the amp does not have fuses.
Old 06-26-2009, 07:54 AM   #8
Ya thats ok, but I dont do that when Im dealing with 1/0.
Simple reason, take for instance my case. I need a wire capable of almost 200 amps. I would run 2Ga but its not common enough and finding things for it is a PITA.
So I dont want to fuse it at 350 Amp when my real draw at the amps is 150. Even though Im only pulling 150 total at amps its advised to bump that up just in case .
Old 06-26-2009, 02:22 PM   #9
Fi-Alero
Fi-Alero's Avatar
Yeah, I have 3 runs of 1/0 from the front battery to the back. But I draw around 410amps of current.
For 2ga accessories, xScorpion makes a few quality products for it, even though they don't carry 2ga wire lol.
