Originally Posted by wilypueo
@darkobsession: He works or used to work at Security and Sound (my friend worked with him there). He does installs as a side job now, so not sure if he is still actively with them or not.
Now that I see this I wanted to add the following.
I would advise you to discuss the thought of dropping your component set down to fill sub bass duties per your PM. See what he has to say about it, if hes a decent/good installer he should tell you not cut it off around 80 Hz or so if amplified- just like I did. He probably wont explain as much though, lol.
Also discuss the rear 6x9 options, Sound Stage Theory, and using a decent 4 channel amp to run the fronts, a set of coaxial 6x9s, a set of 6x9 subs (Tang Band) or bridged to a single subs, like the American Bass DX 12" I recommended.
The DX series is highly regarded as a value sub that performs. Ask Fi Alero. These subs are beasts for the money
