Old 09-21-2010, 05:52 PM   #1
Caboose73
Caboose73's Avatar
Caboose73 is on a distinguished road
Send a message via AIM to Caboose73
No brakes need help
So i just finished installing my MPracing big brake kit i bled the brakes everything was good but as soon as i turn the car on i the peddle goes to the floor and wont build pressure.So after bleeding the front brakes 4-5 times i tried bleeding the whole brake system and the fronts and rear driver side bleed like there supposed to but the rear pass caliber does nothing no air or fluid come out so im stumped and need help trying to figure out whats going on.I also have the ABS light and trac light on i didnt have my scanner at my parents house so i have no idea what codes are coming up but i will check tomorrow and post an update.
Stupidity has an incredible ability to overcome almost any obstacle.
http://www.fquick.com/Caboose73
http://www.aleromod.com/forums/showthread.php?t=27805
Caboose73 is offline   Reply With Quote
Old 09-21-2010, 06:13 PM   #2
mfuller
You do have the bleeder screws pointing up, right?
Old 09-21-2010, 06:16 PM   #3
Caboose73
Caboose73's Avatar
Not sure i just crack them open then close them didnt know they had to be facing a certain way.
Old 09-21-2010, 06:48 PM   #4
mfuller
Well, you can't change the orientation of the bleeder screw itself - it depends on where the bleeder is on hte caliper.
You need to be sure the calipers are oriented in such a way that the bleeder screw is pointing up (you might have the calipers reversed). If the bleeder screws are pointing down you'll never get all the air out of the system.
Old 09-21-2010, 06:56 PM   #5
How can you tell the difference between up and down?
Old 09-21-2010, 07:11 PM   #6
Caboose73
Caboose73's Avatar
I get what your saying and they are pointed down i never thought of that.Thanks ill see if that fixes it tomorrow.
Old 09-21-2010, 07:29 PM   #7
mfuller
This is up - see the bleeder? It has a black rubber cap on it......:
Old 09-21-2010, 09:04 PM   #8
Gotta
Never actually removed a caliper before, but I'm upgrading soon
Old 09-21-2010, 09:35 PM   #9
Caboose73
Caboose73's Avatar
ya i cant believe i didnt see that while i spent a good 2 hours trying everything to make the brakes work.
Old 09-21-2010, 10:35 PM   #10
^^ That is the best way to learn, at least there's a place like this to give you a little help
