it could set a mil light if it was unplugged or a circuit problem. but when they gum up they get slow and i have yet to see a light set for THAT reason. when the car is cold does it idle high like it should? if it idles low all the time then that could be a sign of a stuck iac valve.
if it idles fine some times, and other times it doesnt, find the time that it will idle and thne unplug the iac. this will cause the valve to stay where it is. which means it should now idle at the speed you unplugged it at all the time.
lastly, remove the valve and clean it, if wash and soaked mine a few times in carb cleaner (followed emeditly by a bath of wd-40). that helped but what really did the trick was putting it on our special tool that commanded the valve open and closed. working it helped free the crap up inside and its been good ever since.
