07-22-2008, 01:18 AM
3.4 3.8 turbo!!! $$$$$$900$$$
me and my Buddie have a turbo for a 3.4 or a 3.8 maybe a 3.9L i have many pics of this kit im not sure on the turbo size the kit includes rear exhaust manifold. all the bolts and gaskets you will need machined fuel rails with injectors not sure on size.. chip for the computer might not work with newer model cars ......kit has everything you need to hook it up except the inter cooler tubing.
07-22-2008, 01:49 AM
3.4 is 60* engine
3.8 is 90*
3.9 is 60*
the ports are definitely different so which is it for?
Originally Posted by adam337
Goal - Mid 11s all motor.
07-22-2008, 01:50 AM
3.4 and a 3.8 i was told
07-22-2008, 01:58 AM
well i have both so i wouldnt matter to me... but i dont have any money to spend at the moment
07-22-2008, 09:46 AM
Wide Open Throttle
None of this makes any sense. chips were used until 93-95. THe 3400 came out in 96. You don't have a chip for a 3400 turbo.
The 3800 is completely different and would be a w body only item unless its older. There are no 3800 aleros unless someone went through the trouble to swap it in. You don't have a kit for this setup either.
Are you sure its not a 3.1 MPFI turbo grand prix setup? How about a camaro 3.4 turbo kit?
Machined fuel rails? You don't know what you are talking about. Lets see the pictures of this mystery setup you and your buddy have. How did you happen to come across this setup anyway, without knowing anything about either setup or what size turbo it is?
07-22-2008, 11:55 AM
turbo
the turbo was for a grand prix 3.1 but 3.1s and 3.4 and i believe 3.8s are close enough that the kit will work you will need to buy sum things to make it work on ur car.
07-22-2008, 01:31 PM
3.8 is 90* the ports are not even close to 60* ports. 2.8, 3.1,3.4 and maybe some of the new 60* engines (but im not really sure) might work.
07-22-2008, 01:35 PM
just buy the damn turbo
07-22-2008, 01:43 PM
Fail. Thread lock time.
07-22-2008, 01:48 PM
x2! WERD locky locky.
07-22-2008, 01:52 PM
ibtl. lock this bastard.
07-22-2008, 02:38 PM
07-22-2008, 02:45 PM
wacka wacka
07-22-2008, 03:19 PM
BUSTED!!!
07-22-2008, 03:28 PM
I made chocolate chip pancakes today. eff, they were good.
07-22-2008, 04:22 PM
Nothing can beat my oatmeal cookie pancakes! (raisins, bananas, walnuts, oats, etc.)
07-22-2008, 04:33 PM
STOP! im now hungry....YOU ARENT HELPING THE DIET!
07-22-2008, 04:35 PM
Its ok, Aleros Are roomy
07-22-2008, 05:45 PM
07-22-2008, 06:27 PM
