Originally Posted by pimpalero2003
ull be fine but leave them up when parked in winter
Its more than just that buddy. In the winter where its real cold.. You need to drain ur tank and water trap of any water or moisture like nightly. If you don't.. the water trap can explode and causing the tank to loose all air. And if theres any moisture in the lines.. the lines can freeze where you will have no movement of air if need to raise the car, you'll be stuck.
other than that.. bags are ok to daily drive on.
