Old 06-04-2009, 01:18 PM   #1
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Lpf
Does my headunits low pass filter need to be off or on 78hzs or 128 hzs
Old 06-04-2009, 01:43 PM   #2
It depends on what frequency you want.
This is for your subs, right?
Are you using the LPF on the amp? If you are then you don't really need it on at all.
If you're not then you set it to the desired frequency. Most likely 78Hz (not hzs!).
Old 06-04-2009, 03:18 PM   #3
the amp should have a better filter then your h.u. keep it off on the radio.
and @hertzs.
Old 06-04-2009, 06:08 PM   #4
itsbmw
and @hertzs.
I use 70 hertzs for my LPF.
Old 06-04-2009, 11:27 PM   #5
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Ok I need to double check my amps settings, any recomendations? I'd go look but its pearl harbor with mosqitoes at night
Old 06-05-2009, 08:01 AM   #6
recomendations? theres a little switch you flip from "full" to "LPF" then a dial you adjust to the correct Hz point.
and to clear things up... Hz = hertz. There is no plural. Hence our laughter. its just hertz. always... hertz.
Old 06-05-2009, 11:38 AM   #7
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
I meant about the proper hz setting
Old 06-05-2009, 12:20 PM   #8
its going to be a little dial switch.. with no numbers on it. you just adjust it until you get the desired sound.
