Old 12-28-2007, 04:54 PM   #1
DarkStar
DarkStar is an unknown quantity at this point
amp kick out..
Ok, well i have two 12 inch kicker L7, and im running a 1000 watt kenwood amp to them, and i have gone threw about 20 fuses.. im guess the amp is just not going to be able to handle the subs, so i was wondering is there anything i can do to fix this? or can someone suggest a good amp to replace the kenwood with?
DarkStar is offline   Reply With Quote
Old 12-28-2007, 05:07 PM   #2
AGT
AGT's Avatar
You sure there is not a fault to the amp or a grounded connection in the wiring
Old 12-28-2007, 05:13 PM   #3
DarkStar
went threw, and rewired everything twice, it just seems that when i get to a certain volume level, the amp/fuse gives out.
Old 12-28-2007, 06:39 PM   #4
Is the amp capable to perform to the Ohms you are presenting the amp?
Old 12-29-2007, 01:13 AM   #5
DarkStar
ok, well i found 2 amps that look pretty good to me, i will be running it at 2 ohms, so which do you think would be better out of these two?
http://www.woofersetc.com/index.cfm?...duct_ID=38 76
http://www.woofersetc.com/index.cfm?...duct_ID=31 78
Old 12-29-2007, 01:41 AM   #6
you shouldnt be blowing fuses, check to make sure that you are wiring everything correctly for whatever amplifier you have and make sure there are no shitty connections.
Old 12-29-2007, 01:49 AM   #7
DarkStar
ok, well i will look threw it one more time tomorrow, and get some new connectors and stuff, but if that dosent work i think im going to look into getting one of those amps that i posted..
Old 01-02-2008, 02:34 PM   #8
You may not be providing enough power to the amp there buddy. What size wire are you running for your +12 and ground size 1, 4, or 8? They should be the same size too but not required. Those L7's are dual voice coil aren't they and you are only running a 1000watt amp thats only max right? Get a bigger amp, also like Ryan said is that amp able to handle those subs being wired to 2ohms bridged. If not you lucky you haven't fried it yet.
