03-29-2011, 02:39 PM
Wheels
Thanks to the search feature I know that our bolt pattern is 5x115, but I found a nice set of Pontiac GTO wheels and tires on Craigslist and the bolt pattern is 5x120. Will these fit or can I modify my car to fit them without spending a lot of money?
03-29-2011, 02:41 PM
you could get them redrilled, but it wouldn't really be worth it...
03-29-2011, 07:17 PM
Close only counts in horseshoes and hand greandes
Plus the fact that a GTO is a RWD car, I bet the offset is probably in the low 30's
03-29-2011, 07:18 PM
which would be ok, IF it had the right bolt pattern....
03-30-2011, 01:19 AM
The offset on a GTO is 48mm..
Many RWD cars use high offset wheels nowadays... A 'vette has no wheels with an offset under 50 for quite a while now.
03-30-2011, 01:34 AM
Really?!?!? Cause I was looking at American Racing Torq Thrust for the Alero when I bought the Racelines.
I didn't know that
03-30-2011, 08:35 AM
Ken, where the HELL have you been.... My rims are 17x8 with a +32 offset with 255/40/17s and fit perfect on the front!! The rears are in a little bit which is ok, because I don't won't them sticking out farther looking like a RWD car.....
Which means using something like this it would work.....
http://compare.ebay.com/like/3902996...=263602_304662
Obviously factoring in both the wheel offset and the adaper. In reality you would need a 1" adapter and a mid to high 50 offset in order for it to work...
03-30-2011, 12:47 PM
Exactly, I have C5 mag wheels on my beretta with a spacer. 17x8.6 which weighs under 17 lbs. Not to mention the offset can be perfect because you can get any size spacer you want.
03-31-2011, 10:04 PM
Well if anyone knows of some common cars with factory wheels 17+ with the proper bolt pattern please let me know so that I can keep an eye out around craigslist and the junkyards. I really have no idea what I'm looking for other than I like 5 spoke wheels.
03-31-2011, 10:24 PM
Gran Prix wheels
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
03-31-2011, 11:54 PM
^ fugly......
04-01-2011, 03:10 AM
Bonneville GXP wheels would look nice...
There's a ton of different GM wheels out there that would work... Mine originally came off a CTS.
04-01-2011, 08:21 AM
If I remember right acura tl type s wheels are damn near a perfect fit....but they are hard to get a hold of and sometimes cost as much as new rims.....
04-01-2011, 09:41 AM
those look really similar to your rims..I think I may try and get ahold of a set this summer, maybe..
04-01-2011, 10:09 AM
I'll have to research but I thought when I was looking previously they come factory as 17x8 with a +32 offset, which is the same as mine, and perfect fitment for the front....
04-01-2011, 11:35 AM
Looked it up, the 17x8 acura tl type s rims are made by enkei and have a +45 offset, higher than I would like to see but would still work and look great with a 1/2in spacer.....
04-05-2011, 05:53 PM
Thanks for all of the replies! lots to think about
