07-17-2008, 07:19 PM
Crap... A/C compressor
So well, here's the problem. I noticed that my A/C compressor is making noise, but not all the time. Its like something is loose and metal is slightly rubbing against metal.
Compressor still blows cold. When I engage the A/C (or put it on defrost) the noise is gone. When I turn the A/C back off, noise comes back.
So what now? does it only need some greasing? Could it seize? I guess theres really someone up there that wants me to take my supercharger off and on again!
07-17-2008, 07:36 PM
Mine did that for a while. It went away in time.
07-17-2008, 07:53 PM
H&B Shipping Agent
pretty common my cutlass used to do it, just leave your AC on with the fan off and you wont have a problem. Otherwise it is the clutches in side that need to be replaced.
07-17-2008, 08:09 PM
I'd leave it on, but theres such a difference in power from when the A/C is on and when its not. It also sucks on MPG.
07-17-2008, 08:17 PM
on vacation
mine sounds like a piece of rejected technology that just wont ever die. sorta like a pod racer off of star wars, but alot more quiet- blows ice cold though.
WILL NEVER FORGET
07-18-2008, 12:25 AM
It's the A/C clutch making a "scrubbing" or "whirring" sound. It's really common on the V5 compressors.
07-18-2008, 12:31 AM
i want a v5 engine
Originally Posted by adam337
Goal - Mid 11s all motor.
07-18-2008, 01:38 AM
Originally Posted by 01silveralero
i want a v5 engine
V5 is the Variable displacement 5-cylinder AC compressor.....
07-18-2008, 02:38 AM
Thanks Cliff for the precision.
I dont really care if it makes that kind of noise every once and then, but whats the worse scenario on the long term? A/C not working? compressor Seizing?
07-18-2008, 03:09 AM
compressor wont seize. It just wears the clutch a little bit on the compressor. The clutch can be serviced separately though.
07-18-2008, 06:26 AM
mine made crappy metal scraping noises and turned off when i turned on the a/c, then eventually never turned off, then died. diagnosed compressor clutch fails.
07-18-2008, 09:59 AM
Yeah it sounds like the clutches are starting to go. Nothing to really worry about if the AC is still working as it should.
I never replaced the clutches in mine, I just got a new compressor. My compressor had a hole in it anyway
07-18-2008, 10:00 AM
i want a v5 engine
We are talking compressors here, not enignes.
Again, since you can't tell the difference, maybe you shouldn't be doing this 3800 s/c swap
07-18-2008, 10:22 AM
Ya I was looking at some compressors on Ebay, they arent that expensive. Maybe what I'll do is gather a starter, an Alternator and an A/C compressor and swap them all one shot so I dont have to take the supercharger out 3 times
Silver : Owned !
