Old 06-28-2010, 02:51 PM   #1
knowledge8069
knowledge8069 is an unknown quantity at this point
Cylinder pressure testing for used engines
Hello everyone. I'm in the process of hunting down a 2.4L motor replacement from local junkyards. One place said they have three. They said the best one is from a 2001 Alero which pressure tested at the following numbers:
200 210 210 210 (psi)
Found these numbers on Aleromod sticky "Everything technical on 2.4L." Not sure if these are the numbers for cylinder pressure testing or not:
Oil Pressure @ 3000 RPM 207 kPa 30 psi min.
Oil Pressure @ 900 RPM 69 kPa 10 psi min.
Seems a little odd, maybe they really meant kPa instead of psi when I asked them? Does anyone know what sorts of numbers the 2.4L puts up normally when pressure testing the cylinders? Also, a 2001 2.4L will work in a 2000 without the adapter nut or whatever for the knock sensor right? Are there any other differences?
I've read that pressure testing is a pretty good indicator of the engine's internal condition. Is there anything else I should test or examine to check for faults? The engine is out of the car, so no running it at the yard. They do give a 30 day warranty with the engine, or 1 year for an extra $139. Any advice would be appreciated, as always. Thanks in advance.
knowledge8069 is offline   Reply With Quote
Old 06-28-2010, 03:37 PM   #2
Philbar71
According to the Haynes repair manual they say a minimum of 100 PSI and maximum variation between cylinders 30%
Old 06-28-2010, 04:27 PM   #3
Oldsman
Owner
Oldsman's Avatar
those are good numbers for a compression test.
Beware of the BackStabber
Old 06-28-2010, 04:39 PM   #4
Lucalare
those number you have are the pressure the moving pistons cause on the air in the cylinder, not the oil pressure. And i agree, those number are just about perfect, and far more than my old dodge 318 did.
1987 Honda Rebel 450
Old 06-30-2010, 11:48 PM   #5
knowledge8069
Thanks for the advice, picked up the engine today. =)
