Good morning to all, maybe not for me
I'm new here, the mods are in and things were good for about a month.
Got a custom catback exhaust w/ 2.5" pipe, universal high-flow cat (walker), and a magnaflow muffler w/ dual exhaust. The exhaust manifold stayed the same, on my 2.2L I think it's 1 3/4. I guess it was his preference due to the universal cat, so I'm not sure if its a big deal.
Point is my cat clogged (red hot!!), I was driving the car for approx. a month and the check engine light came on the day after the install. the threading on the o2 sensor was stripped because of the prior mechanic so a new one was purchased.
I ignored the check engine because of reading the higher flow might confuse the o2 sensor, at this time a tune-up was on hold until later this spring.
I do regular maintenance, replace oil every 3 mths, it passed emissions last month before the install with perfect readings. the worst I've needed in 3 years was a fuel pump that was replaced w/ a slightly used one but worked great for over a year. I do knew the computer was not reset and there were minor leaks on the welds for the muffler. (intake and dual outtake)
I'm looking to see what your opinions are, its going in today to have it checked, I cut off the cat to fix a straight pipe but there was a minor leak in the manifold where it connected to the new exhaust and I refused to drive it beyond a few minutes to get smokes. it was still losing power.
Any ideas, seriously dudes... I never had any problems w/ the car and for the entire month it sounded perfect, no damage, drove it earlier that day and went for a nap. I have no clue so I'm waiting for the mechanic to give me word, it might be a few days. Thanks for your help.
-airrazor
