Hi everyone.
Problem:
The engine cranks and will not start.
I've done alot of testing this weekend and hopefully I'll be able to hook up a
tech II to my ride and see what codes it's showing. I hooked up two ODB-II readers to the 'lero and both showed NO CODES, and MIL off, when it is clearly on.
I have spark, The plugs spark and continue to spark during crank.
I have fuel at the rail, the system primes fine when I turn the key to the "on" position.
I have compression, when I spray starter fluid The cylinders fire until the fluid is gone.
Noid light on the injector plugs shows them firing once when I turn the key then they dont fire anymore.
Checked all fuses, and switched the fuel relay with the A/C relay (they're the same) and still nothing.
I switched out the fuel filter at 30,000
Any Ideas?!
Thanks guys.
kou5oku
<img src=\'http://www.luckywebdesign.com/Alero/lloyd%20alero%20sig1.jpg\' border=\'0\' alt=\'user posted image\' />
