Old 09-19-2008, 09:21 PM   #21
Justin081
Justin081's Avatar
Justin081 is on a distinguished road
Send a message via AIM to Justin081
ya the one i go to im not worried about because i know the guy so he will just ignore all that stuff.
http://www.fquick.com/Justin081
Justin081 is offline   Reply With Quote
Old 09-19-2008, 10:47 PM   #22
NickAlero2000
NickAlero2000 is on a distinguished road
yea...i like having hookups in the automotive world
lol
NickAlero2000 is offline   Reply With Quote
Old 09-22-2008, 11:11 PM   #23
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
just put it in the oven for 10 minutes then its enough liquid to get the clear plastic off the assembly pop the orange corner out and reuse the same glue by putting it in the oven an other 2-3 min at like 125 deg.,stick it togheter and your good to go,just use patience!!
leoalero is offline   Reply With Quote
Old 09-25-2008, 01:37 PM   #24
mach3
mach3 is on a distinguished road
Originally Posted by AGT View Post
Then you have to remove the front clear plastic from the assmebly with a combination of heat, knife/screwdriver and patience. Then the little piece pops of the turn signal area.
I need to clear my corners as well. I took a quick look at the assembly last night and notice there is just some black rubbery substance holding the clear cover to the assembly. I'm assuming this black stuff is just glue? So once I remove it, am I going to need buy that type of glue to put it back together?
mach3 is offline   Reply With Quote
Old 09-25-2008, 01:41 PM   #25
that's the silicone, that's what mostpeople use a Hair dryer to get off. Let it turn goopy, then you can get it apart.
Once it solidifies again, Go with an Exacto knife, screwdriver, and whatever you can use to help you, and scrape it off, then run a new bead.
