06-24-2005, 09:15 AM
#61
yay its done.....picked it up last night and got it dropped in...only think left is to bolt up the front tranny mount, intake, and all wiring and hoses.... so about 2 hrs left. I will do that this afternoon....should be runnin by dark!!!
sooooo excited to have it back and running...
this is only the buildup...turbo isnt there yet....that is still to come...i want to get this thing broke in a bit before i throw a hairdryer on it....although I am going to start accumulating the parts.
AnderbrA Innovations
Custom Automotive Lighting
www.anderbrainnovations.com
07 Cadillac STS V8
07 Mitsubishi Galant ES
00 Olds Alero - Parts
02 Lincoln LS V8 Sport - RIP
06-24-2005, 09:26 AM
#62
Pictures!
06-24-2005, 09:35 AM
#63
looks like a stock motor...lol....everything that was done, was done on the inside.
Forged pistons...bored .020 over
Eagle Rods
Balanced rotating assembly
valve job
ported head
ld9 secret cam swap.
grand total so far.... approx $1,850
07 Cadillac STS V8
06-24-2005, 03:36 PM
#64
wow i have a friend that just ordered most of the same stuff for his Z24 cavi. he's plannin on 17psi... he just bought a new engine to do it to though.
06-24-2005, 03:38 PM
#65
Let's Play Army!
dyno numbers!!!!
Originally Posted by black
06-24-2005, 04:26 PM
#66
nice and expensive!, maybe now yo ucan pwn some Oldsman ass lol!
AUTOBOT
06-24-2005, 09:21 PM
#67
Owner
na, we'll both own you..........................lol
Beware of the BackStabber
06-24-2005, 09:23 PM
#68
Owner
Eagle Rods
valve job
ported head
did you keep the balance shafts? did you put in larger valves? did you use ARP studs?
06-24-2005, 10:22 PM
#69
Originally posted by Oldsman+Jun 24 2005, 09:21 PM--><div class='quotetop'>QUOTE(Oldsman @ Jun 24 2005, 09:21 PM)</div><div class='quotemain'><!--QuoteBegin--Alero-@Jun 24 2005, 02:26 PM
nice and expensive!, maybe now yo ucan pwn some Oldsman ass lol!Â;-)
[/b][/quote]
lol i hope so, my car is in the shop unch:
AUTOBOT
06-27-2005, 10:00 AM
#70
Originally posted by Oldsman+Jun 25 2005, 01:23 AM--><div class='quotetop'>QUOTE(Oldsman @ Jun 25 2005, 01:23 AM)</div><div class='quotemain'><!--QuoteBegin-AnderbrA@Jun 24 2005, 07:35 AM
Eagle Rods
valve job
ported head
[/b][/quote]
yes i kept the balance shafts...valves were reground(polished) and no ARP yet.
I do have one issue though....the thing vibrates and rattles everything....any idea what it would be? seems to run fine, but just vibrates the hell out of everything, I dont know if that is because of the cams or what...what do you think?
07 Cadillac STS V8
06-27-2005, 08:46 PM
#71
The cams arnet that aggressive so they shouldnt cause much more engine shake. Is it definately a shake that increases as the engine RPM does? IE is it definately the rotating assembly causing it to shake? Have you checked all engine and tranny mounts? Maybe bring it to the shop to see if they can tell what it is? IE maybe they made a mistake and didnt balance everything properly? Is everything bolted up tightly to the engine?
06-28-2005, 12:38 AM
#72
Owner
if all the mounts are installed and tight and it shakes a lot.
pull it and pull the pan off and check rod and main bolts. if nothing you can see then take it back and have them rebalance it.
oh one last thing..........hows the timing? maybe your timing is off a little.
06-28-2005, 12:40 AM
#73
Owner
so you didn't go really all out. just a mild build up. thats cool.
06-29-2005, 09:16 AM
#74
Yeah, not going to wild with it.....ok heres an update, it still vibrates pretty bad.....everything is bolted up fine, the thing that does concern me is the breather tube coming up that circulates the exhaust back through the intake smokes.....a lot more than usual. Could it be a timing issue? I thought the timing was adjusted by the computer itself?
07 Cadillac STS V8
06-29-2005, 12:14 PM
#75
Owner
timing is set with the cam dowel pins.
as long as you have the cams timed correctly then the computer will adjust.
06-29-2005, 01:35 PM
#76
How am I going to know if the cams are timed correctly? Would that cause it to shake and smoke through the breather tube
07 Cadillac STS V8
06-29-2005, 11:22 PM
#77
Owner
if the cam timing is off it could cause a shake and screw with the engine.
to check cam timing, remove timing chain cover, belt, pulley, mount. by hand rotate the crank around til the timing mark on the chain gear on the crank and the mark on the timing chain housing line up (@ 12 o'clock) then you should be able to slip dowel pins into the timing holes on cam gears. they should slide in and out easily.
that is just one place i would start.
06-30-2005, 10:15 AM
#78
damn.....you want to do it for my Scott?
07 Cadillac STS V8
06-30-2005, 01:51 PM
#79
Owner
lol................sure bring it on out.
06-30-2005, 04:51 PM
#80
im just tired of fkin with this....lol it just should work
07 Cadillac STS V8
