03-26-2011, 12:22 PM
#81
I will have to check the attachment later, work will not display it right now. I am going to call summit racing and have them send out a new O2 sensor with a harness to lengthen it. By the way, if you put these headers in, you will need approximately 28" of extension for the O2 sensor relocation. The sensor and line seem easy to get to so I will put that in myself and hopefully it will take care of it.
You can clear the computer by disconnecting the battery cable and tying the +/- ends together for 15 minutes right? Maybe I will do a couple clears to see if that works...but clearing will clear the PCM settings too so things will just cancel out I bet.
I am buying the hptuners pro from ben. That will hopefully put an end to everything.
03-26-2011, 02:55 PM
#82
Will this fit on the sensor? Does the sensor itself have a plug to plug into?
http://www.casperselectronics.com/st...oducts_id=1162
As for the sound of the headers, I was hoping for a little more. It isn't ricey with the "raaaaaaan" sound; it isn't the deeper power "brum-brum-brum-brum" but more of a "br-br-br-br." This is when driving or revving.
03-26-2011, 05:21 PM
#83
Originally Posted by XanderWiFi
This is one with the factory harness end next to it, your plugs may be light gray instead of black:
03-26-2011, 10:06 PM
#84
I think I saw the steering line. Does it run perpendicular to the pipes at the back of the engine?
It looks like that extension would fit our plugs...
03-27-2011, 09:52 PM
#85
Yeah, and the gray plug (Planar style sensor) is not the same as the black plug (thimble style sensor). While they *basically* work the same, the plugs are not interchangeable.
99-00 should be black, 01-04 should be grey.
03-27-2011, 11:31 PM
#86
I purchased this sensor: http://www.summitracing.com/parts/NGK-21516/
And this extension: http://www.casperselectronics.com/st...oducts_id=1160
That extension is under the pontiac grand am and is listed as the gray wire so I hope it works. Hopefully, the combination of these will alleviate any sensor code issues.
03-29-2011, 01:04 AM
#87
Yeah, that should work just fine... I have that exact style MP150 connector on my desk, it's the right one for the '01+
03-29-2011, 11:18 AM
#88
Thanks Cliff. Any word on that specific line B888?
03-29-2011, 03:48 PM
#89
It runs along close above the back subframe beam and also under the downpipe (perpendicular to the downpipe)
03-30-2011, 07:35 PM
#90
I traced all lines coming out of the power steering pump, the nearest rubber section is at least 6 inches away. The part that runs underneath and near the down pipe are metal. Looks like it has enough clearance to not have any issue.
04-13-2011, 10:20 PM
#91
hate to bring up old news but how did you make out? did the idle smooth out?
04-14-2011, 11:35 PM
#92
I will do a final write up when I get all the SES lights off. I bought the items I listed above from the site recommended on this same thread, installed them, cleared the computer and started up with no SES lights and a smooth idle.
However, when I took it for a drive, shut it down, then turned it back on the SES light had returned. I imagine this is because it is still running lean as it was coded for such in a prior scan.
The idle is smooth now though and the sound is really growing on me. I am waiting on Ben to get a tuner in stock and send it to me so I can get it tuned and hopefully make that lean code disappear...
When I get everything wrapped up I will make a new video and write up for you guys.
04-14-2011, 11:50 PM
#93
15.65 @ 87.3 MPH
I'm glad the pacesetters worked out for you in the end man, you deserve it after all the BS u had to go through lol.
04-15-2011, 12:45 AM
#94
Yeah, it was just a crappy install that made everything go poorly. Everything after has been gravy for the most part. Just a little heater wrap, a little calibration...nothing too terrible for a mod that supposedly gets a solid 15+ hp.
However, a fan blade guard occasionally bumps it and melts some plastic off. Anyone know about some slimmer fans that fit the 3400?
04-15-2011, 07:27 AM
#95
if its just the guard then trim it
04-18-2011, 05:18 AM
#96
good to hear it all worked out in the end.. im thinking about getting some ceramic pacesetter headers here soon idk yet.. found a set for 407$.
Originally Posted by Oldsnut
Originally Posted by tipnitty
04-21-2011, 03:01 PM
#97
i just got my 99 alero coupe 3.4 the other day. i've been looking around but i cant find anything other than cheap ebay intakes. im wanting to do the basic upgrades such as intake, headers, and exhaust but what is a good performance upgrade to start with, and where the heck can i find parts for it? lol i just signed up on here so im new to it. i really appreciate any help with this and i cant wait to get some money into it and make it a heck of a sleeper!
04-21-2011, 03:12 PM
#98
Most people on here have either ebay or another intake for a car.. really an intake is an intake. Just if you get the ebay one put a different filter on it. I've got the ebay one... as for exhaust you can google it.. there's pacesetter and flow master. You can youtube those to see which you like better. Or magnaflow but pacesetter was my choice
As for parts... WOT-TECH.com or milzymotorsports has parts for our car.. I think I have one other website bookmarked on my comp but im on my cell typing this so I can't remember off hand.
I have a 3.4 too. Got a high flow cat, pacesetter exhaust, intake, ngk plugs. Painted the upper intake. Added hids.. new 18 in rims.. spark pplug wires... painted the headlights on the inside and cleared the corners... I love the look of these cars.. check out the site some more it will be helpful.
And welcome to the site.
04-21-2011, 03:38 PM
#99
Go thread jack somewhere else noob. Try searching too.
04-21-2011, 05:14 PM
#100
I agree I was just trying to be nice lol.
He should have posted the question in the new member section. But I just said what the hell and answered it.
