09-01-2008, 05:08 PM
UIM and LIM and timing chain question
I have a 2000 3400 motor will all 3400 upper and lower intakes fit ? I am looking at getting a set to port and polish so they will be ready when I do the gaskets.
timing chain
can it be done without pulling the motor ?
09-01-2008, 05:17 PM
uhhhh yes 3400 manifolds will fit 3400 manifolds
as far as your timing chain.....it can kinda be done with motor still in, your would just have to un do the passenger side motor mount let motor dip (with wooden block support on oil pan) and remove your crank pulley, and then jack your motor up a little and do the upper portion, it can be done but its gonna be one hell of a job
AUTOBOT
09-01-2008, 06:31 PM
AutoCross Alero
there is a difference in upper manifolds, there are 2 different egr valves used depending on yr. timing chain will most likely be a pain in the ass, but can be done while motor is still in the car.
09-01-2008, 11:57 PM
I think 99 and 00 were old style EGR but I am not sure. 99 was different for sure. And I can guarantee that the timing cover and oil pan are going to be a bitch to get off with the engine in the car. Why are you doing the timing chain? They are surprisingly tough, mine showed no visible signs of wear at 130,000 when my engine blew. The keyways on the sprockets seem to be a weak point so if you are in there check those for damage. That is what did me in.
09-02-2008, 12:02 AM
sprockets......they are bad
09-02-2008, 05:12 AM
so I can get a deal on a P&P'ed 3100 upper and lower intake manifolds off a 2000 malibu ? should I get them ?
09-02-2008, 06:51 AM
what!? no! stop with the 3100 stuff
AUTOBOT
09-02-2008, 09:24 AM
Wide Open Throttle
Why? What is wrong with 2000+ 3100 intake manifolds?
09-02-2008, 12:13 PM
Nothing is wrong with them. They are still large port manifolds and there is not difference in the intakes other than saying 3100 on them. Ben do you remember which year they made the EGR change?
09-02-2008, 02:10 PM
its like he doesnt want himself to know its a 3400 and wants a 3100 instead
AUTOBOT
09-02-2008, 02:33 PM
No, P&P 3100 manis would probably be the same as the 3400 manis stock
09-02-2008, 05:46 PM
/\ Read above, 00+ intake manifolds are identical aside from the numbers on the uim.
09-02-2008, 06:12 PM
Wide Open Throttle
2000 was the EGR change, and the better flowing 3100/3400 upper is this style as well.
09-02-2008, 08:21 PM
so p&p 3100 (2000 malibu) is good for a 3400 ?
09-02-2008, 11:59 PM
Exact same manifold as a 3400. You will enjoy ported parts. They really make a difference.
