Old 08-29-2011, 11:35 AM   #1
nicothehut
nicothehut's Avatar
nicothehut is on a distinguished road
Alero transmission Swap ?
Hi,
Can anyone tell me if the transmission in 2002 Alero and 2003 Alero are a straight swap ?
Both came out of 3.4L.
My main concern is if wire connection on the 4T45 are all the same though out the model years.
Thanks for your time anyone.
nicothehut is offline   Reply With Quote
Old 08-29-2011, 12:17 PM   #2
I could only assume they are the same, considering there were no major changes between the two years that I'm aware of
Old 08-29-2011, 12:53 PM   #3
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
In 03 they were built with stronger parts for reliabilty IIRC.
Old 09-01-2011, 12:32 PM   #4
nicothehut
nicothehut's Avatar
Found out that 2001 2002 2003 all have one off year trannsmissions.
Old 09-23-2011, 12:13 AM   #5
nixtux
nixtux's Avatar
nixtux is on a distinguished road
I put a 05' 4t45 from a Grand AM GT in my 99 Alero. Had to change 1 axle and swap a couple pieces over, but all the connectors were the same.
nixtux is offline   Reply With Quote
Old 09-23-2011, 12:21 AM   #6
did you notice any thing different when you drove it ?
Old 09-23-2011, 12:29 AM   #7
nixtux
nixtux's Avatar
A couple things, I'm going to make a post about it shortly. Have a random
issue I'm hoping someone has ran into.
However, when it is working properly, it shifts considerably firmer. I used HP
tuner to update the FDR, remove abuse/torque management and updated it
to match 05' GA GT the transmission came from.
If I get the pressure issue resolved, I'd say it's a better transmission than
the 4t40 that it had, alas, the original did have insane miles (223k) while this
one has 12k.
Old 09-23-2011, 11:01 AM   #8
nixtux
nixtux's Avatar
MT
1999 Alero GLX 4dr Whi
3500 (stock ATM)/4t45e (3.29)
Had a cammed 3500 built but exhaust valves hit.
Cash is tight so time will tell why.
Last edited by nixtux : 09-23-2011 at 11:08 AM. Reason: MT-Wrong thread. First morning after working graveyard all week.
Old 09-23-2011, 04:57 PM   #9
The FDR is 3.29 in the GAGT and that tranny is used as far upto 2009 Malibu.
My tranny is starting to go, so I'm looking
Old 09-24-2011, 12:58 AM   #10
mines starting to go again to i think. might swap it out maybe.
