08-24-2007, 11:14 AM
Quick Question!! NEED HELP
Hello i got a 01 2.4l alero and recently my car service vehicle soon light came on and trac off is on and so is anti-lock...the car still drives the same but i been trying to remove it using the traction button and it does nothing. my friend works at autozone and checked the codes and it read nothing.
p.s. be advised that it said it before i changed the brakes? is theyre a reset button for brakes aswell?
08-24-2007, 12:03 PM
my guess is that an ABS plug is loose on the wheels. When i brought my car in for a tie-rod change one of those plugs came loose and the three lights you mentionned came on. I went back and they made sure everything was plugged in and problem solved. Hope it helps.
08-24-2007, 12:18 PM
I just had this problem, you need a new hub assembly!!
08-24-2007, 01:21 PM
^^ There you go, I've changed both hub assembly in a month and a half 4 months ago.
Check all plugs on the four wheels, but its probly one of the hubs. Wait till it make noise so you know which side to change
08-24-2007, 05:25 PM
i'd say just bring it to a mechanic, they will know which one it is.
My car was loud as effkkk on the highway, it was the front right wheel, after i got it fixed everything was better.
08-24-2007, 08:00 PM
Southern Fly Boy returns
yup that would be it, welcome to one of the most common problems for aleros
08-24-2007, 08:12 PM
Yea thats it! about month ago front Passanger side LOUD LIKE HOLLY eff Friends thought i had aftermarket exhuast soo i told them i did haha. Then when i got it fixed Evrythign WAS perfict Quiet like a umm Alero. lol
