08-04-2006, 07:34 PM
Keepin it Real
RSM vs FFP (pulley talk)
to my knowledge this hasnt been discussed thoroughly. im looking for comments from people who have the RSM crank pulley or the FFP underdrive pulley. which is better????
2015 Audi SQ5
08-04-2006, 08:14 PM
Def FFP. RSM isnt an actual ud pulley,just lighter, and it is much more $
I have an FFP,great mod for the money. More off the line power,revs quicker
08-04-2006, 08:23 PM
Keepin it Real
does the stock belt still fit?
2015 Audi SQ5
08-04-2006, 08:53 PM
I presume you understand that the concept of a true "underdrive" pulley is that it's less drag on the crank from pulley driven accessories, right? Such as A/C, power steering, water pump, tensioner and idler pulleys, and alternator. Benefit is not only less drag on the motor, but at high RPM's it will also prevent your water pump from cavitating.
Personally, the lightened pulley from RSM will let you rev a little bit faster, but the smaller diameter of the underdrive pulley from FFP will do even better for less money.
08-04-2006, 09:13 PM
Keepin it Real
yes i understand that. what about the belt?? stock or a different size?
2015 Audi SQ5
08-05-2006, 12:11 AM
I'd say if the pulley is smaller, you will need a smaller belt.
I have the RSM pulley and I like it, I also have a lightened water pump and the alt pulley too, but that isn't the in the car right now
08-05-2006, 01:03 PM
what I would do is contact FFP and ask them. Tell them what application you have. Simple.
08-05-2006, 01:19 PM
doesn't unorthadox make an underdrive pulley for the alero? if so how does it compare to the RSM and the FFP?
<a href=\'http://www.cardomain.com/ride/2314136\' target=\'_blank\'>My Cardomain</a>
<a href=\'http://emperildesigns.com\' target=\'_blank\'>Tha Club</a>
Were looking for people to join.
08-05-2006, 01:23 PM
yes, they do, it's for the 2.3/2.4, not for the 3400 V6.
jackal2000 is in the V6 category, as is this thread.
08-06-2006, 06:29 AM
i got the FFP pulley, it requires a 1 inch shorter belt.
fairly simple install. i believe someone a long time ago (springsfastestalero) said that the FFP pully was better because it acted more as a dampener which was healthier for your motor in the long run, because the RSM one is just a light pulley, with little to no dampening.
AUTOBOT
08-08-2006, 04:40 PM
Can anybody tell me if the FFP pulley kit is just the crank pulley or does it come with the accesory pulleys as well?
08-08-2006, 04:42 PM
Keepin it Real
its just the crank pulley
here's the link for anyone interested. they ship fast too. i should have mine the 10th.
www.fastfwdperformance.com
2015 Audi SQ5
01-08-2007, 11:55 AM
hey jackal or -Alero-, I am running a sound system that runs at 800 RMS 1600 Watts max, and I was wondering if the FFP pulley will hurt my alternator....
01-08-2007, 11:57 AM
Also, when you ordered your new belt, how did you go about figuring out which belt you needed. If you know which belt exactly it is, I would be very happy if you could share that info...
01-08-2007, 12:16 PM
Keepin it Real
i run 3 12's and 2 amps and the pulley didnt make that big a difference but because of my camshaft my car idles higher than yours so i guess i am the wrong person to give advice on that subject. as far the belt, the goodyear part number is 4060855. however, goodyear is somewhat hard to find unless you order online but give that number to the parts guy at any auto store and they can cross reference for one they have in stock.
2015 Audi SQ5
01-08-2007, 01:18 PM
Aight thanks. Will the pulley bring up any codes from the computer after the installation?
01-08-2007, 01:19 PM
Also does anyone have a FFP pulley they are looking to sell?
01-09-2007, 01:57 AM
Keepin it Real
LOOK HERE!!
$80 shipped
http://60degreev6.com/showthread.php?t=35407
2015 Audi SQ5
01-08-2007, 01:34 PM
Not to be a pain with these questions, but which underdrive pulley did you purchase from FFP. There is two pulleys for the 3.4 DOHC for different year cars. Which one did you purchase or does it matter which one?
01-08-2007, 01:56 PM
Keepin it Real
its the 3rd one down the list
'88 - '05
2.8, 3.1 MPFI and 3100, 3400 SFI
$109.99
you shouldnt have any codes, but if your SES light does come on you will need a crank case learn. they suggest disconnecting the battery for 24hrs to see if that fixes it first.
2015 Audi SQ5
Hybrid Mode
