04-28-2008, 11:38 AM
radio antenna
i bought one of those adapters for a deck so that the radio would work. now i can seem to get any stations whatsoever. could it be possible the adapter went bad or is it time for a new antenna. besides where is the one that comes on the car??
04-28-2008, 11:48 AM
The antenna on the Alero is in the rear windshield. If you had stations before, and now you don't, I highly doubt you have a problem with the actual antenna. More likely than not I would guess a problem with the adapter.
04-28-2008, 12:26 PM
The antenna is powered. You need to run the antenna remote wire to the wire on the harness manually. It s a light green wire I believe.
06-09-2009, 05:36 PM
The Aleromod PITA
ryan i did this like you told me too an now im having issues with the adapter for the radio prong, (the large black wire that doesn't go to the harness).
the piece came from amazon with two things, and i dont even know how to describe it, i got sick of the signal going in and out and have been toying with it for 3 days inspare time, no luck. im gonna run to the car and post a picture of one of the adapter wires, i just took it out because it only seemed to make things worse
06-09-2009, 05:44 PM
The Aleromod PITA
thats the poo poo adapter i took out, it doesn't make any sense to me becasue it doesn't make an actual tight connection with the oem prong
06-09-2009, 11:10 PM
The Aleromod PITA
bump maybe ryan knows
06-09-2009, 11:35 PM
The issue here is the GM antenna is smaller is size than the standard antenna plug.
If the factory plug doesnt fit tight into the end of that one you have, you got the wrong one.
06-09-2009, 11:40 PM
The Aleromod PITA
so that piece that i took out is needed to work properly, see it came with two pieces, the other fits nicely with the oem one and goes directly into the back of the unit, but is allowing the signal to come in and out
do you have any suggestions to make that piece work or do i need to go hunting
am i making sense?
btw i appreciate all your help
06-10-2009, 05:07 AM
say what? i didn't know our antenna was powered... i just plugged my adapter into the deck... other end into car antenna... i get some stations but not as many and not as clearly as before... i can't go very far into town to get stations.
06-10-2009, 10:51 AM
The Aleromod PITA
take the ant rem wire and use a wire tap on the light green wire, itll fix that
The Aleromod PITA
but as to my issue guess i gotta drive 20 miles and 30 minutes drime
06-10-2009, 11:12 PM
The Aleromod PITA
Ahh I'm so pissed with that thin green wire I'm about to cut it strip it back, tie a knot with the ant rem wire and salter over it. Any bad side to this?
06-11-2009, 04:28 AM
its solder..
06-11-2009, 09:51 AM
Calm down guys.
Get a wire tap. The red colored one should work. You slide the tap over the whole wire. Then you slide what you need to connect to it into the scond hole- it doesnt go thru the piece like the other. Clamp down. Done.
However if your replacement deck has a power antenna wire AND a amplifier turn on wire, use the power antenna wire.
I had to use the green wire as my old radio which replaced the stock only had one remote turn on.
06-11-2009, 09:39 PM
The Aleromod PITA
I'm using a red tap now but its still iffy and sry the phone corrected it to salter
